当前版本的文档还未经巡查,您可以查看最新的已查核版本 。
Carefully separate the front and back panels by gently prying them apart. Start at the bottom of the phone (near the AC charger input).
Volume control button will be unsecured and may fall out as soon as the panels are separated.
Gentle force may be required to separate the panels at the top latch.
There are two wires connecting the front and back panels. Be careful not to rip these wires out when separating the panels.
Using your nails, tweezers, or any precise grabbing tool, pinch the antenna wire connector (clear plastic plug) and pull gently. It should pop out rather easily.
Using a SL 1.5 flathead screwdriver (or any small prying tool), pry the speaker from the plastic front cover.
The earpiece speaker is magnetic so you can use a magnet to remove the earpiece speaker from the plastic front cover once loosened.
You can apply your own adhesive to secure your replaced speaker if desired during reassembly.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
单个步骤
完整指南
小——600像素
中——800像素
大——1200像素
预览
