跳转到主内容
修复你的物品
维修的权力
商店
简介
Replacing the earpiece speaker
  1. Rotate the phone onto its front side so that the LCD screen is facing away from you.
    • Rotate the phone onto its front side so that the LCD screen is facing away from you.
  2. Remove the battery by pressing down on the battery release button while sliding the battery downwards. Remove the battery by pressing down on the battery release button while sliding the battery downwards. Remove the battery by pressing down on the battery release button while sliding the battery downwards.
    • Remove the battery by pressing down on the battery release button while sliding the battery downwards.
  3. Remove the four small black screws that secure the back phone panel using the Phillips #00 screwdriver.
    • Remove the four small black screws that secure the back phone panel using the Phillips #00 screwdriver.
    • Complete removal of screws may not be necessary.
  4. Carefully separate the front and back panels by gently prying them apart.  Start at the bottom of the phone (near the AC charger input). Volume control button will be unsecured and may fall out as soon as the panels are separated. Gentle force may be required to separate the panels at the top latch.
    • Carefully separate the front and back panels by gently prying them apart. Start at the bottom of the phone (near the AC charger input).
    • Volume control button will be unsecured and may fall out as soon as the panels are separated.
    • Gentle force may be required to separate the panels at the top latch.
    • There are two wires connecting the front and back panels. Be careful not to rip these wires out when separating the panels.
  5. Using your nails, tweezers, or any precise grabbing tool, pinch the antenna wire connector (clear plastic plug) and pull gently. It should pop out rather easily. Using your nails, tweezers, or any precise grabbing tool, pinch the antenna wire connector (clear plastic plug) and pull gently. It should pop out rather easily.
    • Using your nails, tweezers, or any precise grabbing tool, pinch the antenna wire connector (clear plastic plug) and pull gently. It should pop out rather easily.
  6. Put aside the back panel. You will only be working with the front panel from here on.
    • Put aside the back panel. You will only be working with the front panel from here on.
  7. Using a SL 1.5 flathead screwdriver (or any small prying tool), pry the speaker from the plastic front cover. The earpiece speaker is magnetic so you can use a magnet to remove the earpiece speaker from the plastic front cover once loosened. You can apply your own adhesive to secure your replaced speaker if desired during reassembly.
    • Using a SL 1.5 flathead screwdriver (or any small prying tool), pry the speaker from the plastic front cover.
    • The earpiece speaker is magnetic so you can use a magnet to remove the earpiece speaker from the plastic front cover once loosened.
    • You can apply your own adhesive to secure your replaced speaker if desired during reassembly.
结论
Chris Lao
于2010年04月15日注册
1 信誉积分
撰写一个指南
团队
Cal Poly, Team 28-29, Regan Spring 2010 Cal Poly, Team 28-29, Regan Spring 2010 的会员
CPSU-REGAN-S10S28G29
4 名成员
创作了12篇指南
Where can I get a replacement speaker?
NickyPhils - 回复
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 1,908
