跳转到主内容
Samsung SGH-X105 Earpiece Speaker Replacement
你所需要的
  1. Samsung SGH-X105 Earpiece Speaker Replacement, Battery: 步骤 1 中的图像 1,1
    • Rotate the phone onto its front side so that the LCD screen is facing away from you.
  2. Samsung SGH-X105 Earpiece Speaker Replacement: 步骤 2 中的图像 1,3 Samsung SGH-X105 Earpiece Speaker Replacement: 步骤 2 中的图像 2,3 Samsung SGH-X105 Earpiece Speaker Replacement: 步骤 2 中的图像 3,3
    • Remove the battery by pressing down on the battery release button while sliding the battery downwards.
  3. Samsung SGH-X105 Earpiece Speaker Replacement, Front & Back Panels: 步骤 3 中的图像 1,1
    • Remove the four small black screws that secure the back phone panel using the Phillips #00 screwdriver.
    • Complete removal of screws may not be necessary.
  4. Samsung SGH-X105 Earpiece Speaker Replacement: 步骤 4 中的图像 1,3 Samsung SGH-X105 Earpiece Speaker Replacement: 步骤 4 中的图像 2,3 Samsung SGH-X105 Earpiece Speaker Replacement: 步骤 4 中的图像 3,3
    • Carefully separate the front and back panels by gently prying them apart. Start at the bottom of the phone (near the AC charger input).
    • Volume control button will be unsecured and may fall out as soon as the panels are separated.
    • Gentle force may be required to separate the panels at the top latch.
    • There are two wires connecting the front and back panels. Be careful not to rip these wires out when separating the panels.
  5. Samsung SGH-X105 Earpiece Speaker Replacement: 步骤 5 中的图像 1,2 Samsung SGH-X105 Earpiece Speaker Replacement: 步骤 5 中的图像 2,2
    • Using your nails, tweezers, or any precise grabbing tool, pinch the antenna wire connector (clear plastic plug) and pull gently. It should pop out rather easily.
  6. Samsung SGH-X105 Earpiece Speaker Replacement, Earpiece Speaker: 步骤 6 中的图像 1,1
    • Put aside the back panel. You will only be working with the front panel from here on.
  7. Samsung SGH-X105 Earpiece Speaker Replacement: 步骤 7 中的图像 1,3 Samsung SGH-X105 Earpiece Speaker Replacement: 步骤 7 中的图像 2,3 Samsung SGH-X105 Earpiece Speaker Replacement: 步骤 7 中的图像 3,3
    • Using a SL 1.5 flathead screwdriver (or any small prying tool), pry the speaker from the plastic front cover.
    • The earpiece speaker is magnetic so you can use a magnet to remove the earpiece speaker from the plastic front cover once loosened.
    • You can apply your own adhesive to secure your replaced speaker if desired during reassembly.
结论
另外一个人完成了本指南。
Chris Lao
于04/15/10注册
16 声望
撰写一个指南
团队
Cal Poly, Team 28-29, Regan Spring 2010 Cal Poly, Team 28-29, Regan Spring 2010 的会员
CPSU-REGAN-S10S28G29
4 名成员
创作了12篇指南
一条评论
Where can I get a replacement speaker?
NickyPhils - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 2
总计 1,941
