当前版本的文档还未经巡查,您可以查看最新的已查核版本。
Locate the two screws (3mm) at the base of the top portion of the cell phone.
Remove screws using a phillips head #000 screwdriver.
Place screws on magnetic mat.
Locate the seam of the casing along the edge of the phone.
Starting at the end, gently begin to pry the front casing away from the phone. Use the plastic opening tool for this step.
Locate the small battery at the end of the cell phone.
Gently remove the battery from the cell phone using tweezers.
Note: This may require some force.
Do not disconnect the battery from the entire phone. Simply lift the battery from the cell phone while keeping the wires connected.
Locate the speaker at the end of the cell phone.
Gently grasp and lift the speaker from the cell phone using tweezers.
Do not disconnect the speaker from the entire cell phone. Simply lift the speaker while leaving the wires connected.
Locate the top tabs of the screen and circuit board unit
Gently lift the screen and circuit board as one unit from the cell phone using the tweezers.
Make sure the screen and circuit board are removed as one unit. Do not disconnect the screen from the circuit board.
Locate the gold connector that is attached to the circuit board.
Pull the connection away from the circuit board.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
预览
