跳转到主内容
Samsung SGH-T639 Screen Replacement
你所需要的
  1. Samsung SGH-T639 Screen Replacement, Screen: 步骤 1 中的图像 1,3 Samsung SGH-T639 Screen Replacement, Screen: 步骤 1 中的图像 2,3 Samsung SGH-T639 Screen Replacement, Screen: 步骤 1 中的图像 3,3
    • Flip phone over and locate the screw covers.
    • Remove the two thin screw covers using the tweezers.
  2. Samsung SGH-T639 Screen Replacement: 步骤 2 中的图像 1,3 Samsung SGH-T639 Screen Replacement: 步骤 2 中的图像 2,3 Samsung SGH-T639 Screen Replacement: 步骤 2 中的图像 3,3
    在这个步骤中使用的工具:
    Magnetic Project Mat
    $19.95
    购买
    • Locate the two screws (3mm) at the base of the top portion of the cell phone.
    • Remove screws using a phillips head #000 screwdriver.
    • Place screws on magnetic mat.
  3. Samsung SGH-T639 Screen Replacement: 步骤 3 中的图像 1,2 Samsung SGH-T639 Screen Replacement: 步骤 3 中的图像 2,2
    • Locate the seam of the casing along the edge of the phone.
    • Starting at the end, gently begin to pry the front casing away from the phone. Use the plastic opening tool for this step.
  4. Samsung SGH-T639 Screen Replacement: 步骤 4 中的图像 1,3 Samsung SGH-T639 Screen Replacement: 步骤 4 中的图像 2,3 Samsung SGH-T639 Screen Replacement: 步骤 4 中的图像 3,3
    • Continue to pry the casing from the front of the cell phone.
    • Remove front casing from the cell phone.
  5. Samsung SGH-T639 Screen Replacement: 步骤 5 中的图像 1,3 Samsung SGH-T639 Screen Replacement: 步骤 5 中的图像 2,3 Samsung SGH-T639 Screen Replacement: 步骤 5 中的图像 3,3
    • Locate the small battery at the end of the cell phone.
    • Gently remove the battery from the cell phone using tweezers.
    • Note: This may require some force.
    • Do not disconnect the battery from the entire phone. Simply lift the battery from the cell phone while keeping the wires connected.
  6. Samsung SGH-T639 Screen Replacement: 步骤 6 中的图像 1,3 Samsung SGH-T639 Screen Replacement: 步骤 6 中的图像 2,3 Samsung SGH-T639 Screen Replacement: 步骤 6 中的图像 3,3
    • Locate the speaker at the end of the cell phone.
    • Gently grasp and lift the speaker from the cell phone using tweezers.
    • Do not disconnect the speaker from the entire cell phone. Simply lift the speaker while leaving the wires connected.
  7. Samsung SGH-T639 Screen Replacement: 步骤 7 中的图像 1,3 Samsung SGH-T639 Screen Replacement: 步骤 7 中的图像 2,3 Samsung SGH-T639 Screen Replacement: 步骤 7 中的图像 3,3
    • Locate the tip of the sheer protection film.
    • Gently lift and remove the protection film with tweezers.
  8. Samsung SGH-T639 Screen Replacement: 步骤 8 中的图像 1,3 Samsung SGH-T639 Screen Replacement: 步骤 8 中的图像 2,3 Samsung SGH-T639 Screen Replacement: 步骤 8 中的图像 3,3
    • Locate the top tabs of the screen and circuit board unit
    • Gently lift the screen and circuit board as one unit from the cell phone using the tweezers.
    • Make sure the screen and circuit board are removed as one unit. Do not disconnect the screen from the circuit board.
  9. Samsung SGH-T639 Screen Replacement: 步骤 9 中的图像 1,3 Samsung SGH-T639 Screen Replacement: 步骤 9 中的图像 2,3 Samsung SGH-T639 Screen Replacement: 步骤 9 中的图像 3,3
    • Locate the gold connector that is attached to the circuit board.
    • Pull the connection away from the circuit board.
  10. Samsung SGH-T639 Screen Replacement: 步骤 10 中的图像 1,1
    • Completely remove the screen and circuit board unit from the cell phone.
结论
Yi Ren
于03/26/14注册
801 声望
创作了8篇指南
团队
Clemson, Team 1-4, Benson Spring 2014 Clemson, Team 1-4, Benson Spring 2014 的会员
CLEM-BENSON-S14S1G4
3 名成员
创作了16篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 14
总计 373
