当前版本的文档还未经巡查,您可以查看最新的已查核版本。
这个步骤还没有翻译 帮忙翻译一下
Remove the plastic coverings at the base of the LCD screen using your fingers.
Use the screwdriver to remove the two 4.5mm screws located underneath the plastic coverings.
You may want to use tweezers to remove the loosened screws.
Wedge the plastic opening tool under the crevice on the inner surface of the phone screen.
Gently pry the top panel off around the entire frame.
Make sure that the top panel is completely separated from the LCD display around the entire perimeter.
Take the top panel off of the phone.
Use the wedge to detach the connecting wire panel from the LCD display system.
Be gentle when dethatching this wire to prevent damaging surrounding components.
Use the tweezers to remove the camera from the cellphone casing.
取消:我没有完成这个指南。
与7其他贡献者
于01/30/11注册
101 声望
撰写一个指南
徽章: 3
CPSU-MANESS-W11S11G23
4 名成员
创作了10篇指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 21
总计 1,522
