跳转到主内容
Samsung SGH-A237 Logic Board Replacement
你所需要的
  1. Samsung SGH-A237 Logic Board Replacement, Logic Board: 步骤 1 中的图像 1,2 Samsung SGH-A237 Logic Board Replacement, Logic Board: 步骤 1 中的图像 2,2
    • Put the phone face down so that the battery cover is showing.
  2. Samsung SGH-A237 Logic Board Replacement: 步骤 2 中的图像 1,2 Samsung SGH-A237 Logic Board Replacement: 步骤 2 中的图像 2,2
    • Use your thumb to push the cover down and off.
    • Lift the battery off the device.
  3. Samsung SGH-A237 Logic Board Replacement: 步骤 3 中的图像 1,2 Samsung SGH-A237 Logic Board Replacement: 步骤 3 中的图像 2,2
    • Remove the five screws with a size 00 screwdriver. There 4 in the corners and one on the top as shown.
  4. Samsung SGH-A237 Logic Board Replacement: 步骤 4 中的图像 1,3 Samsung SGH-A237 Logic Board Replacement: 步骤 4 中的图像 2,3 Samsung SGH-A237 Logic Board Replacement: 步骤 4 中的图像 3,3
    • Be sure that all 5 screws are removed and start to carefully remove the back cover by using the iPod Opening Tool in the slots on the bottom of the device.
    • Note: some force must be applied when removing back cover.
  5. Samsung SGH-A237 Logic Board Replacement: 步骤 5 中的图像 1,1
    • Detach the tab from the logic board by using iPod Opening Tool (as shown).
  6. Samsung SGH-A237 Logic Board Replacement: 步骤 6 中的图像 1,2 Samsung SGH-A237 Logic Board Replacement: 步骤 6 中的图像 2,2
    • Use iPod Opening Tool to lift the green logic board carefully.
    • Remove logic board from the device and replace with new one.
结论
Theodore Johansen
于04/14/10注册
1 声望
创作了2篇指南
团队
Cal Poly, Team 29-81, Johann Spring 2010 Cal Poly, Team 29-81, Johann Spring 2010 的会员
CPSU-JOHANN-S10S29G81
4 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 3
总计 2,805
