跳转到主内容
Samsung SGH-A237 Keypad Replacement
你所需要的
  1. Samsung SGH-A237 Keypad Replacement, Keypad: 步骤 1 中的图像 1,2 Samsung SGH-A237 Keypad Replacement, Keypad: 步骤 1 中的图像 2,2
    • Place phone face down so battery cover is showing.
  2. Samsung SGH-A237 Keypad Replacement: 步骤 2 中的图像 1,2 Samsung SGH-A237 Keypad Replacement: 步骤 2 中的图像 2,2
    • Use thumb to push the cover down and off.
    • Lift battery cover off the device.
  3. Samsung SGH-A237 Keypad Replacement: 步骤 3 中的图像 1,2 Samsung SGH-A237 Keypad Replacement: 步骤 3 中的图像 2,2
    • Remove the five screws with a size 00 screwdriver. There are 4 in the corners and one on the top as shown.
  4. Samsung SGH-A237 Keypad Replacement: 步骤 4 中的图像 1,3 Samsung SGH-A237 Keypad Replacement: 步骤 4 中的图像 2,3 Samsung SGH-A237 Keypad Replacement: 步骤 4 中的图像 3,3
    • Be sure that all 5 screws are removed and start to carefully remove the back cover by using the iPod Opening Tool in the slots on the bottom of the device.
    • Some force must be applied, and the back cover should come off.
  5. Samsung SGH-A237 Keypad Replacement: 步骤 5 中的图像 1,1
    • Detach the tab from the logic board shown by using the Ipod Opening Tool
  6. Samsung SGH-A237 Keypad Replacement: 步骤 6 中的图像 1,2 Samsung SGH-A237 Keypad Replacement: 步骤 6 中的图像 2,2
    • Use the Ipod Opening Tool to lift the green logic board carefully.
    • Remove the logic board from the device.
  7. Samsung SGH-A237 Keypad Replacement: 步骤 7 中的图像 1,1
    • The keypad should peel off the logic board with a gentle pull.
    • Use a clean, soft, cotton cloth to gently remove any debris or liquid that may be located on the pad or logic board interface.
结论
Shawn
于04/14/10注册
1 声望
创作了2篇指南
团队
Cal Poly, Team 29-81, Johann Spring 2010 Cal Poly, Team 29-81, Johann Spring 2010 的会员
CPSU-JOHANN-S10S29G81
4 名成员
创作了8篇指南
一条评论
This was very helpful. There is no other place I could find a guide to take this phone apart. Even Samsung chat was unable to help!! Thanks very much!
Steve - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 14
总计 2,316
