跳转到主内容
Samsung SGH-A137 Motherboard Replacement
你所需要的
  1. Samsung SGH-A137 Motherboard Replacement, Battery: 步骤 1 中的图像 1,1
    • Use your thumbs to pull down on the back cover to remove it and expose the battery.
  2. Samsung SGH-A137 Motherboard Replacement: 步骤 2 中的图像 1,1
    • Locate the indent in the case below the battery. (see red square)
    • Place your finger at the indent and pull up on the battery to remove it.
  3. Samsung SGH-A137 Motherboard Replacement, Motherboard: 步骤 3 中的图像 1,3 Samsung SGH-A137 Motherboard Replacement, Motherboard: 步骤 3 中的图像 2,3 Samsung SGH-A137 Motherboard Replacement, Motherboard: 步骤 3 中的图像 3,3
    • Locate the 4 screw holes and remove the 0.4 mm Phillips head screws using a #000 Phillips head screwdriver. (See red circles)
  4. Samsung SGH-A137 Motherboard Replacement: 步骤 4 中的图像 1,1
    • Using a plastic opening tool, gently pry open the back of the phone at the seam.
    • Carefully work the tool all the way around the opening while prying up to avoid breaking the plastic retaining clips.
  5. Samsung SGH-A137 Motherboard Replacement: 步骤 5 中的图像 1,2 Samsung SGH-A137 Motherboard Replacement: 步骤 5 中的图像 2,2
    • Smaller press-fit connectors may require a simple flick with a plastic opening tool or spudger.
    • Place the flat edge of a spudger under the edge of the press-fit connector and , gently pry the connector straight up from its socket. (Highlighted by the red square)
  6. Samsung SGH-A137 Motherboard Replacement: 步骤 6 中的图像 1,1
    • Using a plastic opening tool, gently pry up the motherboard.
    • You might need to pry from several different locations to get the motherboard loose enough to remove.
结论
3等其他人完成本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 5
总计 542
