跳转到主内容
你所需要的
这个拆解是不是维修指南。 要维修你的的Samsung SGH-A117,请使用我们的维修手册
  1. Samsung SGH-A117: Breakdown and Reassembly, Samsumg SGH-A117: 步骤 1 中的图像 1,1
    • This is the Samsung SGH-A117.
  2. Samsung SGH-A117: Breakdown and Reassembly, Backside of the cellphone: 步骤 2 中的图像 1,1
    • This is the back view following the removal of the back cover and battery.
  3. Samsung SGH-A117: Breakdown and Reassembly, Removing Screws: 步骤 3 中的图像 1,1
    • Use a screwdriver to remove screws around the frame.
    • Use a PH00 size screw to operate this step.
    • The screws are extremely small. It is recommended to have a small container to keep track of the screws.
  4. Samsung SGH-A117: Breakdown and Reassembly, Removing the Back Cover: 步骤 4 中的图像 1,2 Samsung SGH-A117: Breakdown and Reassembly, Removing the Back Cover: 步骤 4 中的图像 2,2
    • Insert the spudger under the back cover at the marked locations and gently lift to remove the back cover.
    • The end of the phone closest to the hinge will require additional force to lift.
    • Be careful not to bend the cover during the removal process.
  5. Samsung SGH-A117: Breakdown and Reassembly, Separate Circuit Connector from Logic Board: 步骤 5 中的图像 1,1
    • Use a spudger to gently lift the circuit connector from the logic board.
    • Be careful not to remove the circuit connector from the phone.
  6. Samsung SGH-A117: Breakdown and Reassembly, Lift Logic Board: 步骤 6 中的图像 1,2 Samsung SGH-A117: Breakdown and Reassembly, Lift Logic Board: 步骤 6 中的图像 2,2
    • Use a spudger to lift the logic board and separate it from the main body of the phone.
    • It is recommended to lift from the bottom part of the logic board as shown in the picture.
    • Be careful not to lose the volume button, which is loosely attached to the logic board.
  7. Samsung SGH-A117: Breakdown and Reassembly, Remove Keypad: 步骤 7 中的图像 1,2 Samsung SGH-A117: Breakdown and Reassembly, Remove Keypad: 步骤 7 中的图像 2,2
    • Gently push the keyboard from the case as shown in the picture.
  8. Samsung SGH-A117: Breakdown and Reassembly, Layout of Disassembled Device: 步骤 8 中的图像 1,1
    • 1 Case
    • 1 Keyboard
    • 1 Logic Board
    • 1 Volume Control
    • 1 Back Cover
    • 5 Screws
Justin
于10/06/14注册
150 声望
创作了2篇指南
团队
Aristotle Aristotle 的会员
Community
5 名成员
创作了3篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 10
总计 827
