跳转到主内容
Samsung SGH-A117 Motherboard Replacement
你所需要的
  1. Samsung SGH-A117 Motherboard Replacement, Battery: 步骤 1 中的图像 1,1
    • Remove the battery by pressing the battery lock down and slide the battery cover away.
  2. Samsung SGH-A117 Motherboard Replacement: 步骤 2 中的图像 1,1
    • Lift the bottom of the battery and then move it up and away.
  3. Samsung SGH-A117 Motherboard Replacement, Motherboard: 步骤 3 中的图像 1,1
    • Locate the 4 screws holes on the phone and remove them with the #000 Philips Head screwdriver. (See red circles)
  4. Samsung SGH-A117 Motherboard Replacement: 步骤 4 中的图像 1,1
    • Using the plastic opening tool, gently pry open the back piece of the phone.
    • Make sure to do this very carefully, as the back part of the phone is very thin and fragile.
  5. Samsung SGH-A117 Motherboard Replacement: 步骤 5 中的图像 1,1
    • Use the metal prying tool to gently flick up the rectangular connector. (Because this device is on the smaller side, the rectangular connector may only need a simple flick with the prying tool)
    • Simply flick the rectangular connector up from its socket. (Highlighted by the red square)
  6. Samsung SGH-A117 Motherboard Replacement: 步骤 6 中的图像 1,1
    • Use the plastic opening tool to gently pry up the motherboard.
    • You may need to pry the motherboard up from several angles in order to remove it.
结论
2等其他人完成本指南。
Stephanie Isaac
于09/11/15注册
431 声望
创作了3篇指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 9
总计 255
