跳转到主内容
简介
Is your screen broken or faulty? This guide will help you replace it.
  1. Unscrew all visible screws indicated by red circles with a #00 Phillips driver. Slide memory card cover and unscrew hidden screw  underneath with a #00 Phillips driver. Slide memory card cover and unscrew hidden screw  underneath with a #00 Phillips driver.
    • Unscrew all visible screws indicated by red circles with a #00 Phillips driver.
    • Slide memory card cover and unscrew hidden screw underneath with a #00 Phillips driver.
  2. Remove the flat side panel by applying gentle pressure toward the bottom of the camera. Remove the corner panel by applying pressure away from the shutter button. The memory card cover will come off with the corner panel.
    • Remove the flat side panel by applying gentle pressure toward the bottom of the camera.
    • Remove the corner panel by applying pressure away from the shutter button.
    • The memory card cover will come off with the corner panel.
    • Remove the top panel by applying gentle pressure away from the shutter button.
  3. PC 笔记本电池
    所有顶级PC品牌的电池均以我们的质量保证为后盾。
    现在开始购物
    PC 笔记本电池
    现在开始购物
  4. Remove screws beneath the top panel indicated by red circles with a #00 Phillips driver.
    • Remove screws beneath the top panel indicated by red circles with a #00 Phillips driver.
  5. Remove the front and back covers by pulling them straight apart. Remove the front and back covers by pulling them straight apart.
    • Remove the front and back covers by pulling them straight apart.
  6. Open the ribbon connector with your fingernail. Pull the ribbon out of the connection. Pull the ribbon out of the connection.
    • Open the ribbon connector with your fingernail.
    • Pull the ribbon out of the connection.
  7. Pull the ribbon connected to the screen out from behind the button circuitry on the rear of the camera.
    • Pull the ribbon connected to the screen out from behind the button circuitry on the rear of the camera.
    • Feed the new screen's ribbon through the same slot it came out of.
结论
Evert Jordan
于2018年02月08日注册
282 信誉积分
创作了2篇指南
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 14
