跳转到主内容
修复你的物品
维修的权力
配件 & 工具
简介
Is your flash weak or not working at all? It could be your flash capacitor. Here's a replacement guide to help.
  1. Unscrew all visible screws indicated by red circles with a #00 Phillips driver. Slide memory card cover and unscrew hidden screw  underneath with a #00 Phillips driver. Slide memory card cover and unscrew hidden screw  underneath with a #00 Phillips driver.
    • Unscrew all visible screws indicated by red circles with a #00 Phillips driver.
    • Slide memory card cover and unscrew hidden screw underneath with a #00 Phillips driver.
  2. Remove the flat side panel by applying gentle pressure toward the bottom of the camera. Remove the corner panel by applying pressure away from the shutter button. The memory card cover will come off with the corner panel.
    • Remove the flat side panel by applying gentle pressure toward the bottom of the camera.
    • Remove the corner panel by applying pressure away from the shutter button.
    • The memory card cover will come off with the corner panel.
    • Remove the top panel by applying gentle pressure away from the shutter button.
  3. Remove screws beneath the top panel indicated by red circles with a #00 Phillips driver.
    • Remove screws beneath the top panel indicated by red circles with a #00 Phillips driver.
  4. Manta 螺丝刀工具包
    日常维修的112个替换头
    Upgrade Your Toolbox
    Manta 螺丝刀工具包
  5. Remove the front and back covers by pulling them straight apart. Remove the front and back covers by pulling them straight apart.
    • Remove the front and back covers by pulling them straight apart.
  6. Remove the screw securing the shutter button. Lift the shutter button to remove it.
    • Remove the screw securing the shutter button.
    • Lift the shutter button to remove it.
  7. Remove the 3 visible screws with a Phillips #000 Driver Move the circuitry and wires out of the way to expose another screw, and remove it with the same driver.
    • Remove the 3 visible screws with a Phillips #000 Driver
    • Move the circuitry and wires out of the way to expose another screw, and remove it with the same driver.
  8. Pull the flash capacitor out of its compartment to expose the wires connected to it. Cut the connecting wires with wire cutters. Solder the wires to the new power source with a soldering iron and electrical solder.
    • Pull the flash capacitor out of its compartment to expose the wires connected to it.
    • Cut the connecting wires with wire cutters.
    • Solder the wires to the new power source with a soldering iron and electrical solder.
结论
Evert Jordan
于2018年02月08日注册
281 信誉积分
创作了2篇指南
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 1
总计 63
