跳转到主内容
Samsung SCV-VLUUST50 Flash Bulb Replacement
你所需要的
  1. Samsung SCV-VLUUST50 Flash Bulb Replacement, Cover: 步骤 1 中的图像 1,3 Samsung SCV-VLUUST50 Flash Bulb Replacement, Cover: 步骤 1 中的图像 2,3 Samsung SCV-VLUUST50 Flash Bulb Replacement, Cover: 步骤 1 中的图像 3,3
    • Unscrew all visible screws indicated by red circles with a #00 Phillips driver.
    • Slide memory card cover and unscrew hidden screw underneath with a #00 Phillips driver.
  2. Samsung SCV-VLUUST50 Flash Bulb Replacement: 步骤 2 中的图像 1,3 Samsung SCV-VLUUST50 Flash Bulb Replacement: 步骤 2 中的图像 2,3 Samsung SCV-VLUUST50 Flash Bulb Replacement: 步骤 2 中的图像 3,3
    • Remove the flat side panel by applying gentle pressure toward the bottom of the camera.
    • Remove the corner panel by applying pressure away from the shutter button.
    • The memory card cover will come off with the corner panel.
    • Remove the top panel by applying gentle pressure away from the shutter button.
  3. Samsung SCV-VLUUST50 Flash Bulb Replacement: 步骤 3 中的图像 1,1
    • Remove screws beneath the top panel indicated by red circles with a #00 Phillips driver.
  4. Samsung SCV-VLUUST50 Flash Bulb Replacement: 步骤 4 中的图像 1,2 Samsung SCV-VLUUST50 Flash Bulb Replacement: 步骤 4 中的图像 2,2
    • Remove the front and back covers by pulling them straight apart.
  5. Samsung SCV-VLUUST50 Flash Bulb Replacement, Flash Bulb: 步骤 5 中的图像 1,2 Samsung SCV-VLUUST50 Flash Bulb Replacement, Flash Bulb: 步骤 5 中的图像 2,2
    • Remove the screw securing the shutter button to the camera frame.
    • Lift the shutter button to remove it.
  6. Samsung SCV-VLUUST50 Flash Bulb Replacement: 步骤 6 中的图像 1,2 Samsung SCV-VLUUST50 Flash Bulb Replacement: 步骤 6 中的图像 2,2
    • Remove the screws from the circuitry with a Phillips #000 driver.
    • Remove the screw connecting the flash housing to the camera frame with the same driver.
  7. Samsung SCV-VLUUST50 Flash Bulb Replacement: 步骤 7 中的图像 1,2 Samsung SCV-VLUUST50 Flash Bulb Replacement: 步骤 7 中的图像 2,2
    • Pull the flash housing away from the camera frame.
    • Cut the wires connecting the flash module to the circuitry.
    • Connect the new flash module to the circuitry with a soldering iron and electrical solder.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 134
