跳转到主内容
Samsung SCH-U340 Lower Casing Replacement
你所需要的
  1. Samsung SCH-U340 Lower Casing Replacement, Battery: 步骤 1 中的图像 1,1
    • Turn the cell phone so that the back side is facing you.
    • Press the upper indent and slide the back cover down.
  2. Samsung SCH-U340 Lower Casing Replacement: 步骤 2 中的图像 1,1
    • Pull the battery up from indent at the bottom and slide it out.
  3. Samsung SCH-U340 Lower Casing Replacement: 步骤 3 中的图像 1,1
    • Set the battery aside.
  4. Samsung SCH-U340 Lower Casing Replacement, Lower Casing: 步骤 4 中的图像 1,1
    • The lower casing is held on by four screws in the corner of the battery enclosure. Remove these screws.
  5. Samsung SCH-U340 Lower Casing Replacement: 步骤 5 中的图像 1,2 Samsung SCH-U340 Lower Casing Replacement: 步骤 5 中的图像 2,2
    • Use a spudger to pry the back assembly off of the device.
结论
团队
Cal Poly, Team 3-21, Maness Winter 2010 Cal Poly, Team 3-21, Maness Winter 2010 的会员
CPSU-MANESS-W10S3G21
4 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 3,606
