本指南有最近更改,您可查看未经巡查的最新版本。
简介
Use this guide to remove the logic board assembly from the casing.
你所需要的
Turn the cell phone so that the back side is facing you.
Press the upper indent and slide the back cover down.
The outer casing consists of two separate parts on the upper and lower halves of the device. The upper outer casing is held on through a combination of screws and tabs.
First, remove the plastic plugs covering the screws with a spudger.
The lower casing is held on by four screws in the corner of the battery enclosure. Remove these screws.
即将完成!
终点
