跳转到主内容
Samsung SCH-A950 Volume and Camera Buttons Replacement
你所需要的
  1. Samsung SCH-A950 Volume and Camera Buttons Replacement, Battery: 步骤 1 中的图像 1,2 Samsung SCH-A950 Volume and Camera Buttons Replacement, Battery: 步骤 1 中的图像 2,2
    • Slide the the battery release tab upwards while simultaneously lifting the back cover straight up.
  2. Samsung SCH-A950 Volume and Camera Buttons Replacement, Volume and Camera Buttons: 步骤 2 中的图像 1,1
    • Remove the four Phillips #00 screws underneath the battery.
  3. Samsung SCH-A950 Volume and Camera Buttons Replacement: 步骤 3 中的图像 1,2 Samsung SCH-A950 Volume and Camera Buttons Replacement: 步骤 3 中的图像 2,2
    • Pull open the earphone tab and the Trans Flash tab using your fingers.
  4. Samsung SCH-A950 Volume and Camera Buttons Replacement: 步骤 4 中的图像 1,1
    • Using a plastic opening tool, pry off the phone casing near the speakers as shown. Tabs located on the inside of the phone may make this difficult and some force may be required.
    • Slide the casing slightly forward towards the top of the phone to remove.
  5. Samsung SCH-A950 Volume and Camera Buttons Replacement: 步骤 5 中的图像 1,3 Samsung SCH-A950 Volume and Camera Buttons Replacement: 步骤 5 中的图像 2,3 Samsung SCH-A950 Volume and Camera Buttons Replacement: 步骤 5 中的图像 3,3
    • Using tweezers or your fingers, lift off buttons from logic board.
    • The buttons can be replaced if needed.
结论
另外一个人完成了本指南。
Sean Kennedy
于01/13/10注册
49 声望
撰写一个指南
团队
Cal Poly, Team 11-5, Forte Winter 2010 Cal Poly, Team 11-5, Forte Winter 2010 的会员
CPSU-FORTE-W10S11G5
5 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 1,865
