本指南有最近更改,您可查看未经巡查的最新版本。
简介
This guide will teach you how to remove your Samsung SCH-A950's logic board.
你所需要的
Slide the the battery release tab upwards while simultaneously lifting the back cover straight up.
Use tweezers to peel back the sticker on the backside of the speaker to reveal a screw that holds the speaker in place.
Using a phillips #00 screwdriver, remove the screw holding the speaker. On each side.
Using a plastic opening tool, disconnect the display cable from the motherboard.
即将完成!
结论
