当前版本的文档还未经巡查,您可以查看最新的已查核版本。
这个步骤还没有翻译 帮忙翻译一下
Slide the latch on the back of the phone up.
Remove the battery.
After removing the battery, remove the four small Phillips-head screws with a #0 Phillips screwdriver.
Using a thumbtack, pry the small plastic cover from the case near the base of the antenna.
With a #0 Phillips screwdriver remove the screw which you just uncovered.
Using the spudger, carefully pry the case apart starting near the charging port. Ease the case open.
Then disconnect the small power connector near the top of the phone.
Gently pry up the ribbon-type connector with the spudger.
Carefully pry the logic board from the case with the spudger.
Once the logic board has been removed, peel the keypad up.
When using a spudger the keypad housing comes off quite easily, although it may be necessary to guide the ribbon cable through the slot in the housing.
Remove screws with #0 Phillips screwdriver.
Carefully pry apart the casing with the spudger tool.
Use the spudger to carefully pry off the speaker.
Carefully pry off the ringer with the spudger.
Carefully pry off the screen with the spudger.
取消:我没有完成这个指南。
与5其他贡献者
于04/11/10注册
19 声望
创作了7篇指南
徽章: 8
+ 5更多徽章
CPSU-FORTE-S10S34G59
4 名成员
创作了14篇指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 13
总计 3,427
