简介
The screen casing may become worn or broken over time. This guide will allow you to remove/replace it.
配件
无需配件。
  1. Slide the latch on the back of the phone up.
    • Slide the latch on the back of the phone up.
  2. Remove the battery.
    • Remove the battery.
  3. After removing the battery, remove the four small Phillips-head screws with a #0 Phillips screwdriver.
    • After removing the battery, remove the four small Phillips-head screws with a #0 Phillips screwdriver.
  4. Using a thumbtack, pry the small plastic cover from the case near the base of the antenna.
    • Using a thumbtack, pry the small plastic cover from the case near the base of the antenna.
  5. 所有超过US$100或包含 Pro Tech工具包的订单免费送货!
    浏览我们的商店
  6. With a #0 Phillips screwdriver remove the screw which you just uncovered.
    • With a #0 Phillips screwdriver remove the screw which you just uncovered.
  7. Using the spudger, carefully pry the case apart starting near the charging port. Ease the case open. Then disconnect the small power connector near the top of the phone.
    • Using the spudger, carefully pry the case apart starting near the charging port. Ease the case open.
    • Then disconnect the small power connector near the top of the phone.
  8. Gently pry up the ribbon-type connector with the spudger.
    • Gently pry up the ribbon-type connector with the spudger.
  9. Carefully pry the logic board from the case with the spudger.
    • Carefully pry the logic board from the case with the spudger.
  10. Once the logic board has been removed, peel the keypad up.
    • Once the logic board has been removed, peel the keypad up.
  11. When using a spudger the keypad housing comes off quite easily, although it may be necessary to guide the ribbon cable through the slot in the housing. When using a spudger the keypad housing comes off quite easily, although it may be necessary to guide the ribbon cable through the slot in the housing.
    • When using a spudger the keypad housing comes off quite easily, although it may be necessary to guide the ribbon cable through the slot in the housing.
  12. Remove screws with #0 Phillips screwdriver.
    • Remove screws with #0 Phillips screwdriver.
  13. Carefully pry apart the casing with the spudger tool.
    • Carefully pry apart the casing with the spudger tool.
结论
Nathan Brink
于2010年04月11日注册
1 信誉积分
创作了7篇指南
团队
Cal Poly, Team 34-59, Forte Spring 2010 Cal Poly, Team 34-59, Forte Spring 2010 的会员
CPSU-FORTE-S10S34G59
4 名成员
创作了14篇指南
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 3
总计 1,822
