跳转到主内容
Samsung SCH-A670 Logic Board Replacement
你所需要的
  1. Samsung SCH-A670 Logic Board Replacement, Battery Cover: 步骤 1 中的图像 1,1
    • Slide the latch on the back of the phone up.
  2. Samsung SCH-A670 Logic Board Replacement, Battery: 步骤 2 中的图像 1,1
    • Remove the battery.
  3. Samsung SCH-A670 Logic Board Replacement, Logic Board: 步骤 3 中的图像 1,1
    • After removing the battery, remove the four small Phillips-head screws with a #0 Phillips screwdriver.
  4. Samsung SCH-A670 Logic Board Replacement: 步骤 4 中的图像 1,1
    • Using a thumbtack, pry the small plastic cover from the case near the base of the antenna.
  5. Samsung SCH-A670 Logic Board Replacement: 步骤 5 中的图像 1,1
    • With a #0 Phillips screwdriver remove the screw which you just uncovered.
  6. Samsung SCH-A670 Logic Board Replacement: 步骤 6 中的图像 1,2 Samsung SCH-A670 Logic Board Replacement: 步骤 6 中的图像 2,2
    • Using the spudger, carefully pry the case apart starting near the charging port. Ease the case open.
    • Then disconnect the small power connector near the top of the phone.
  7. Samsung SCH-A670 Logic Board Replacement: 步骤 7 中的图像 1,1
    • Gently pry up the ribbon-type connector with the spudger.
  8. Samsung SCH-A670 Logic Board Replacement: 步骤 8 中的图像 1,1
    • Carefully pry the logic board from the case with the spudger.
终点
另外一个人完成了本指南。
Nathan Brink
于04/11/10注册
19 声望
创作了7篇指南
团队
Cal Poly, Team 34-59, Forte Spring 2010 Cal Poly, Team 34-59, Forte Spring 2010 的会员
CPSU-FORTE-S10S34G59
4 名成员
创作了14篇指南
一条评论
Perfect instructions to remove the back of the case. Thanks
John Berg - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 15
总计 2,766
