跳转到主内容
Samsung SCH-A670 Camera Replacement
你所需要的
  1. Samsung SCH-A670 Camera Replacement, Battery Cover: 步骤 1 中的图像 1,1
    • Slide the latch on the back of the phone up.
  2. Samsung SCH-A670 Camera Replacement, Battery: 步骤 2 中的图像 1,1
    • Remove the battery.
  3. Samsung SCH-A670 Camera Replacement, Logic Board: 步骤 3 中的图像 1,1
    • After removing the battery, remove the four small Phillips-head screws with a #0 Phillips screwdriver.
  4. Samsung SCH-A670 Camera Replacement: 步骤 4 中的图像 1,1
    • Using a thumbtack, pry the small plastic cover from the case near the base of the antenna.
  5. Samsung SCH-A670 Camera Replacement: 步骤 5 中的图像 1,1
    • With a #0 Phillips screwdriver remove the screw which you just uncovered.
  6. Samsung SCH-A670 Camera Replacement: 步骤 6 中的图像 1,2 Samsung SCH-A670 Camera Replacement: 步骤 6 中的图像 2,2
    • Using the spudger, carefully pry the case apart starting near the charging port. Ease the case open.
    • Then disconnect the small power connector near the top of the phone.
  7. Samsung SCH-A670 Camera Replacement: 步骤 7 中的图像 1,1
    • Gently pry up the ribbon-type connector with the spudger.
  8. Samsung SCH-A670 Camera Replacement: 步骤 8 中的图像 1,1
    • Carefully pry the logic board from the case with the spudger.
  9. Samsung SCH-A670 Camera Replacement, Keypad: 步骤 9 中的图像 1,1
    • Once the logic board has been removed, peel the keypad up.
  10. Samsung SCH-A670 Camera Replacement, Keypad Housing: 步骤 10 中的图像 1,2 Samsung SCH-A670 Camera Replacement, Keypad Housing: 步骤 10 中的图像 2,2
    • When using a spudger the keypad housing comes off quite easily, although it may be necessary to guide the ribbon cable through the slot in the housing.
  11. Samsung SCH-A670 Camera Replacement, Screen Casing: 步骤 11 中的图像 1,1
    • Remove screws with #0 Phillips screwdriver.
  12. Samsung SCH-A670 Camera Replacement: 步骤 12 中的图像 1,1
    • Carefully pry apart the casing with the spudger tool.
  13. Samsung SCH-A670 Camera Replacement, Screen: 步骤 13 中的图像 1,1
    • Use the spudger to carefully pry off the speaker.
  14. Samsung SCH-A670 Camera Replacement: 步骤 14 中的图像 1,1
    • Carefully pry off the ringer with the spudger.
  15. Samsung SCH-A670 Camera Replacement: 步骤 15 中的图像 1,1
    • Carefully pry off the screen with the spudger.
  16. Samsung SCH-A670 Camera Replacement, Camera: 步骤 16 中的图像 1,1
    • Gently pry off the camera with the spudger.
结论
Nathan Brink
于04/11/10注册
19 声望
创作了7篇指南
团队
Cal Poly, Team 34-59, Forte Spring 2010 Cal Poly, Team 34-59, Forte Spring 2010 的会员
CPSU-FORTE-S10S34G59
4 名成员
创作了14篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 4,152
