跳转到主内容
Samsung SCH-A310 Display Casing Replacement
你所需要的
  1. Samsung SCH-A310 Display Casing Replacement, Display Casing: 步骤 1 中的图像 1,3 Samsung SCH-A310 Display Casing Replacement, Display Casing: 步骤 1 中的图像 2,3 Samsung SCH-A310 Display Casing Replacement, Display Casing: 步骤 1 中的图像 3,3
    • With the phone upright and folded shut, locate the two silver tabs at the top of the screen.
    • Using one hand, pinch the two tabs inward, and use your other hand to slide the front cover of the screen off of the phone.
    • Note: Do not apply too much of force. If you find it difficult to remove the front cover, try pinching the tabs in harder, and make sure you are sliding the front cover directly downward.
  2. Samsung SCH-A310 Display Casing Replacement: 步骤 2 中的图像 1,2 Samsung SCH-A310 Display Casing Replacement: 步骤 2 中的图像 2,2
    • Using the T6 Torx screwdriver, remove each of the 4mm screws located in the corners of the phone.
    • Be sure to keep track of the little screws, since they can be lost easily.
  3. Samsung SCH-A310 Display Casing Replacement: 步骤 3 中的图像 1,2 Samsung SCH-A310 Display Casing Replacement: 步骤 3 中的图像 2,2
    • Locate the tabs on either side of the phone. Pull the outer case away from each tab with the plastic opening tool.
  4. Samsung SCH-A310 Display Casing Replacement: 步骤 4 中的图像 1,3 Samsung SCH-A310 Display Casing Replacement: 步骤 4 中的图像 2,3 Samsung SCH-A310 Display Casing Replacement: 步骤 4 中的图像 3,3
    • Hold the phone upside-down.
    • Two plastic tabs are located under the lip of your phone. Use a plastic opening tool to pop the outer case away from the tabs.
    • After the outside case is clear of the four tabs, removed it.
结论
To replace one of the screens, follow the corresponding guide from this point on. To reassemble your device, follow these instructions in reverse order.
Anthony Cisneros
于01/20/12注册
1 声望
创作了2篇指南
团队
Cal Poly, Team 11-23, Maness Winter 2012 Cal Poly, Team 11-23, Maness Winter 2012 的会员
CPSU-MANESS-W12S11G23
4 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 1,018
