跳转到主内容
修复你的物品
维修的权力
配件 & 工具
简介
This guide will teach you how to get to and replace the plastic keypad from the phone.
配件
没有特定配件。
  1. To separate the battery from the phone, use your thumb to push in the button as shown. Keep the unlock button pressed as you slide the battery away from the button. Pull the battery away from the phone.
    • To separate the battery from the phone, use your thumb to push in the button as shown.
    • Keep the unlock button pressed as you slide the battery away from the button.
    • Pull the battery away from the phone.
  2. Use a T6 Torx screwdriver to remove the highlighted screws. These are the four screws, about 10 mm long, that need to be removed. Be careful with the screws as they are small and easy to misplace. Carefully pry apart the two pieces, laying the back case to the side.
    • Use a T6 Torx screwdriver to remove the highlighted screws.
    • These are the four screws, about 10 mm long, that need to be removed. Be careful with the screws as they are small and easy to misplace.
    • Carefully pry apart the two pieces, laying the back case to the side.
  3. With the back case fully removed and out of the way, use your fingers to remove the volume button. Use caution in removal to prevent damaging any circuitry in the phone. Use caution in removal to prevent damaging any circuitry in the phone.
    • With the back case fully removed and out of the way, use your fingers to remove the volume button.
    • Use caution in removal to prevent damaging any circuitry in the phone.
  4. The circuit board is hardwired to other components in the phone and cannot be completely removed. Take extreme precaution when performing this step as to not damage the circuitry or the wiring. Lift the circuit board up slightly. With the circuit board lifted, remove the plastic keypad and place to the side.
    • The circuit board is hardwired to other components in the phone and cannot be completely removed. Take extreme precaution when performing this step as to not damage the circuitry or the wiring.
    • Lift the circuit board up slightly.
    • With the circuit board lifted, remove the plastic keypad and place to the side.
结论
Will Gunter
于2012年10月23日注册
1 信誉积分
创作了4篇指南
团队
Clemson, Team 14-6, Benson Fall 2012 Clemson, Team 14-6, Benson Fall 2012 的会员
CLEM-BENSON-F12S14G6
3 名成员
创作了12篇指南
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 180
