跳转到主内容
Samsung SCH-3500 Logic Board Replacement
你所需要的
  1. Samsung SCH-3500 Logic Board Replacement, Battery: 步骤 1 中的图像 1,2 Samsung SCH-3500 Logic Board Replacement, Battery: 步骤 1 中的图像 2,2
    • Place the phone so that the back is facing you. Depress the locking tab on the back of the phone with a finger or thumb.
  2. Samsung SCH-3500 Logic Board Replacement: 步骤 2 中的图像 1,1
    • Slide the battery toward bottom of the phone, about a quarter of an inch, to clear the hooks that keep it secured to the back of the phone.
  3. Samsung SCH-3500 Logic Board Replacement: 步骤 3 中的图像 1,1
    • Lift the battery away from the phone case.
  4. Samsung SCH-3500 Logic Board Replacement, Antenna: 步骤 4 中的图像 1,2 Samsung SCH-3500 Logic Board Replacement, Antenna: 步骤 4 中的图像 2,2
    • Grasp the antenna firmly and rotate it counterclockwise to unscrew it from the phone.
  5. Samsung SCH-3500 Logic Board Replacement: 步骤 5 中的图像 1,1
    • When unscrewed, pull the antenna straight up and out.
  6. Samsung SCH-3500 Logic Board Replacement: 步骤 6 中的图像 1,2 Samsung SCH-3500 Logic Board Replacement: 步骤 6 中的图像 2,2
    • Pull the guide tube free from its retaining ring and slide it out the top.
  7. Samsung SCH-3500 Logic Board Replacement, Back Cover: 步骤 7 中的图像 1,1
    • Remove the four screws using a T6 Torx screwdriver.
  8. Samsung SCH-3500 Logic Board Replacement: 步骤 8 中的图像 1,2 Samsung SCH-3500 Logic Board Replacement: 步骤 8 中的图像 2,2
    • Work from the bottom of the phone, separating the two halves of the case.
    • Note: Take care to keep the logic board with the front case half. Part of the logic board is exposed to the sticker under the battery on the rear case half.
  9. Samsung SCH-3500 Logic Board Replacement: 步骤 9 中的图像 1,1
    • Angle the rear case half away from the top of the front case half, pivoting the hooks out of their clasps.
    • Caution: Do not fully separate the halves. There is an antenna ribbon connected to the logic board from the back cover.
  10. Samsung SCH-3500 Logic Board Replacement: 步骤 10 中的图像 1,3 Samsung SCH-3500 Logic Board Replacement: 步骤 10 中的图像 2,3 Samsung SCH-3500 Logic Board Replacement: 步骤 10 中的图像 3,3
    • Disconnect the antenna ribbon cable from the logic board at the Zero Insertion Force (ZIF) connector. The brown portion of the connector lifts up to release the cable end.
    • The Back Cover is now removed. Congratulations.
  11. Samsung SCH-3500 Logic Board Replacement, Logic Board: 步骤 11 中的图像 1,1
    • Remove the connector for the earpiece speaker, located on the upper end of the logic board.
  12. Samsung SCH-3500 Logic Board Replacement: 步骤 12 中的图像 1,1
    • Turn the front cover over, gently prying the logic board away from the front cover. It will remain attached by two wires from the front of the board.
  13. Samsung SCH-3500 Logic Board Replacement: 步骤 13 中的图像 1,2 Samsung SCH-3500 Logic Board Replacement: 步骤 13 中的图像 2,2
    • Work the microphone out of its socket on the front cover; it will remain attached to the logic board, its wires are soldered.
    • The logic board is now removed from the phone. Congratulations.
结论
团队
Clemson, Team 2-6, Benson Spring 2012 Clemson, Team 2-6, Benson Spring 2012 的会员
CLEM-BENSON-S12S2G6
2 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 811
