工具
无需工具。
配件
无需配件。
  1. Turn Samsung SCH3500 around so that the back is facing you. Depress locking tab on the back of the phone with a finger or thumb. Turn Samsung SCH3500 around so that the back is facing you. Depress locking tab on the back of the phone with a finger or thumb.
    • Turn Samsung SCH3500 around so that the back is facing you. Depress locking tab on the back of the phone with a finger or thumb.
  2. Slide battery toward bottom of the phone, ~1/4 inch, to clear the hooks that keep it secured to the back of the phone.
    • Slide battery toward bottom of the phone, ~1/4 inch, to clear the hooks that keep it secured to the back of the phone.
  3. 所有超过US$100.00或包含 Pro Tech工具包的订单免费送货!
    浏览我们的商店
    善于维修,即天赋异禀。
    与 #ImAGenius 分享您的维修故事
    我们都是天才
  4. Lift battery away from phone case.
    • Lift battery away from phone case.
    • The battery is now removed from the device. Congratulations.
  5. Grasp antenna firmly and rotate counterclockwise to unscrew it from the phone. Grasp antenna firmly and rotate counterclockwise to unscrew it from the phone.
    • Grasp antenna firmly and rotate counterclockwise to unscrew it from the phone.
  6. When unscrewed, pull the antenna straight up and out.
    • When unscrewed, pull the antenna straight up and out.
  7. Pull guide tube free from its retaining ring and slide it out the top, like the antenna (optional). The antenna and its guide tube are now removed from the phone. Congratulations.
    • Pull guide tube free from its retaining ring and slide it out the top, like the antenna (optional).
    • The antenna and its guide tube are now removed from the phone. Congratulations.
结论
Brett Tomashitis
于2012年03月09日注册
36 信誉积分
创作了5篇指南
团队
Clemson, Team 2-6, Benson Spring 2012 Clemson, Team 2-6, Benson Spring 2012 的会员
CLEM-BENSON-S12S2G6
2 名成员
创作了10篇指南
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 625
