跳转到主内容
加入维修社区 - 创建账户
Samsung S860 Motherboard Replacement
你所需要的
    1. Samsung S860 Motherboard Replacement, Battery: 步骤 1 中的图像 1,3 Samsung S860 Motherboard Replacement, Battery: 步骤 1 中的图像 2,3 Samsung S860 Motherboard Replacement, Battery: 步骤 1 中的图像 3,3
      • With the camera facing LCD side up, slide the battery compartment lid to the right.
      • Remove the old batteries.
      询问修复机器人
      添加评论
    1. Samsung S860 Motherboard Replacement, LCD Screen: 步骤 2 中的图像 1,2 Samsung S860 Motherboard Replacement, LCD Screen: 步骤 2 中的图像 2,2
      • Remove all screws along the edges of the camera, using a #00 Phillips screwdriver.
      询问修复机器人
      添加评论
    2. Samsung S860 Motherboard Replacement: 步骤 3 中的图像 1,1
      • Slide open the battery compartment cover before removing the exterior covers of the camera.
      询问修复机器人
      添加评论
    3. Samsung S860 Motherboard Replacement: 步骤 4 中的图像 1,3 Samsung S860 Motherboard Replacement: 步骤 4 中的图像 2,3 Samsung S860 Motherboard Replacement: 步骤 4 中的图像 3,3
      • Carefully pull the back case (the side showing the LCD screen) away from the front half.
      • There are clips securing the top of the back case. Do not be afraid to use the proper amount of force to remove the back case.
      • Turn the camera around to the front (the lens side). Carefully remove the front case.
      • There are also clips on the lens' side as well, so do not be afraid to use force.
      询问修复机器人
      添加评论
    4. Samsung S860 Motherboard Replacement: 步骤 5 中的图像 1,2 Samsung S860 Motherboard Replacement: 步骤 5 中的图像 2,2
      • Position the camera so the LCD screen is facing you.
      • Remove the LCD screen from the screen plate.
      • Replace the broken LCD screen with the functioning LCD screen.
      询问修复机器人
      添加评论
    1. Samsung S860 Motherboard Replacement, Motherboard: 步骤 6 中的图像 1,2 Samsung S860 Motherboard Replacement, Motherboard: 步骤 6 中的图像 2,2
      • Using a #00 Phillips screwdriver, remove the six 4.3 mm screws along the edges of the camera.
      • Save them for putting the camera back together.
      询问修复机器人
      添加评论
    2. Samsung S860 Motherboard Replacement: 步骤 7 中的图像 1,1
      • Turn the bottom edge of the camera towards you.
      • Slide open the battery chamber.
      • This must be done to remove the exterior covers of the camera.
      询问修复机器人
      添加评论
    3. Samsung S860 Motherboard Replacement: 步骤 8 中的图像 1,3 Samsung S860 Motherboard Replacement: 步骤 8 中的图像 2,3 Samsung S860 Motherboard Replacement: 步骤 8 中的图像 3,3
      • Carefully pull the back of the camera (the LCD screen side) away from the front.
      • Turn the camera to the front (the flash side) and pull the case off.
      • There are clips on both sides of the case that secure it to the camera, so you may need to use a bit of force to remove the case.
      询问修复机器人
      添加评论
    4. Samsung S860 Motherboard Replacement: 步骤 9 中的图像 1,2 Samsung S860 Motherboard Replacement: 步骤 9 中的图像 2,2
      • Orient the camera so the LCD screen is facing you.
      • Remove any tape holding the screen down.
      • Lift the LCD screen from the screen plate.
      • Lift the hinged lip on the camera body where the ribbon cable enters the connector.
      • Remove the ribbon from the logic board by gently pulling it straight out.
      • Try not to kink or crease the cable.
      询问修复机器人
      添加评论
    5. Samsung S860 Motherboard Replacement: 步骤 10 中的图像 1,1
      • Using a #00 Philips screwdriver, remove the two 4.5 mm screws from the screen plate.
      • Separate the screen plate and logic board.
      询问修复机器人
      添加评论
    6. Samsung S860 Motherboard Replacement: 步骤 11 中的图像 1,1
      • Locate the brown ribbon cable attached to the upper left edge of the logic board.
      • Remove this ribbon by gently pulling in the opposite direction of the logic board.
      询问修复机器人
      添加评论
    7. Samsung S860 Motherboard Replacement: 步骤 12 中的图像 1,1
      • Using a #00 Philips screwdriver, remove the three 3.32 mm screws connecting the logic board to the camera.
      • Separate the logic board and the core of the camera.
      询问修复机器人
      添加评论
    8. Samsung S860 Motherboard Replacement: 步骤 13 中的图像 1,1
      • Separate the logic board by carefully pulling the logic board away from the camera.
      • Be careful not to damage the battery compartment. The battery sensors are attached to the logic board, so be gentle.
      • The USB connector is going to want to hang up on the housing, but once you have that free, the battery leads will slide out relatively easily.
      询问修复机器人
      添加评论
结论
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
取消:我没有完成这个指南。
2等其他人完成本指南。
团队
Cal Poly, Team 33-72, Johann Spring 2010 Cal Poly, Team 33-72, Johann Spring 2010 的会员
CPSU-JOHANN-S10S33G72
4 名成员
创作了35篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 9
过去 30 天: 55
总计 10,142
