跳转到主内容
Samsung S860 Logic Board Replacement
你所需要的
  1. Samsung S860 Logic Board Replacement, Battery: 步骤 1 中的图像 1,3 Samsung S860 Logic Board Replacement, Battery: 步骤 1 中的图像 2,3 Samsung S860 Logic Board Replacement, Battery: 步骤 1 中的图像 3,3
    • With the camera facing LCD side up, slide the battery compartment lid to the right.
    • Remove the old batteries.
  2. Samsung S860 Logic Board Replacement, LCD Screen: 步骤 2 中的图像 1,2 Samsung S860 Logic Board Replacement, LCD Screen: 步骤 2 中的图像 2,2
    • Remove all screws along the edges of the camera, using a #00 Phillips screwdriver.
  3. Samsung S860 Logic Board Replacement: 步骤 3 中的图像 1,1
    • Slide open the battery compartment cover before removing the exterior covers of the camera.
  4. Samsung S860 Logic Board Replacement: 步骤 4 中的图像 1,3 Samsung S860 Logic Board Replacement: 步骤 4 中的图像 2,3 Samsung S860 Logic Board Replacement: 步骤 4 中的图像 3,3
    • Carefully pull the back case (the side showing the LCD screen) away from the front half.
    • There are clips securing the top of the back case. Do not be afraid to use the proper amount of force to remove the back case.
    • Turn the camera around to the front (the lens side). Carefully remove the front case.
    • There are also clips on the lens' side as well, so do not be afraid to use force.
  5. Samsung S860 Logic Board Replacement: 步骤 5 中的图像 1,2 Samsung S860 Logic Board Replacement: 步骤 5 中的图像 2,2
    • Position the camera so the LCD screen is facing you.
    • Remove the LCD screen from the screen plate.
    • Replace the broken LCD screen with the functioning LCD screen.
  6. Samsung S860 Logic Board Replacement, Logic Board: 步骤 6 中的图像 1,2 Samsung S860 Logic Board Replacement, Logic Board: 步骤 6 中的图像 2,2
    • The screws should be 4.3 mm in length.
    • Save them for putting the camera back together.
  7. Samsung S860 Logic Board Replacement: 步骤 7 中的图像 1,1
    • Turn the bottom edge of the camera towards you.
    • Slide open the battery chamber.
    • This must be done to remove the exterior covers of the camera.
  8. Samsung S860 Logic Board Replacement: 步骤 8 中的图像 1,3 Samsung S860 Logic Board Replacement: 步骤 8 中的图像 2,3 Samsung S860 Logic Board Replacement: 步骤 8 中的图像 3,3
    • Carefully pull the back of the camera (the LCD screen side) away from the front.
    • Turn the camera to the front (the flash side). Carefully remove.
    • There are clips on this side as well. Again, do not be afraid to use force.
  9. Samsung S860 Logic Board Replacement: 步骤 9 中的图像 1,2 Samsung S860 Logic Board Replacement: 步骤 9 中的图像 2,2
    • Orient the camera so the LCD screen is facing you.
    • Remove any tape holding it down, and then lift the LCD screen from the screen plate.
    • Lift the hinged lip where the ribbon enters the connector. Remove the ribbon from the logic board by pulling it gently away from the logic board.
  10. Samsung S860 Logic Board Replacement: 步骤 10 中的图像 1,1
    • Remove all screws from the screen plate, using a #00 Philips screwdriver.
    • The screws should be 4.5 mm in length.
    • Separate the screen plate and logic board.
  11. Samsung S860 Logic Board Replacement: 步骤 11 中的图像 1,1
    • There is another ribbon attached to the logic board. It is located on the upper left edge of the logic board.
    • Similar to the other ribbon, remove by gently pulling in the opposite direction of the logic board. The "ears" on the cable can be used to help pull it free.
  12. Samsung S860 Logic Board Replacement: 步骤 12 中的图像 1,1
    • Using a #00 Philips screwdriver, unscrew the screws connecting the logic board to the camera.
    • You should be removing three 3.32 mm long screws.
    • Separate the logic board and the core of the camera.
  13. Samsung S860 Logic Board Replacement: 步骤 13 中的图像 1,1
    • To separate the logic board from the camera, carefully pull the logic board away from the camera.
    • Be careful not to damage the battery compartment. The battery sensors are attached to the logic board, so be gentle.
    • The USB connector is going to want to hang up on the housing, but once you have that free, the battery leads will slide out relatively easily.
结论
2等其他人完成本指南。
Kando Ogunrinola
于04/17/10注册
185 声望
创作了3篇指南
团队
Cal Poly, Team 33-72, Johann Spring 2010 Cal Poly, Team 33-72, Johann Spring 2010 的会员
CPSU-JOHANN-S10S33G72
4 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 25
总计 9,239
