简介
The logic board is the "motherboard" of the camera that contains all of the main circuits and important components necessary to make the device run efficiently. If the logic board is old, faulty, or damaged, this may prevent the camera from working properly.
你所需要的
With the camera facing LCD side up, slide the battery compartment lid to the right.
Remove the old batteries.
Remove all screws along the edges of the camera, using a #00 Phillips screwdriver.
Carefully pull the back case (the side showing the LCD screen) away from the front half.
There are clips securing the top of the back case. Do not be afraid to use the proper amount of force to remove the back case.
Turn the camera around to the front (the lens side). Carefully remove the front case.
There are also clips on the lens' side as well, so do not be afraid to use force.
Using a #00 Phillips screwdriver, remove the six 4.3 mm screws along the edges of the camera.
Save them for putting the camera back together.
Orient the camera so the LCD screen is facing you.
Remove any tape holding the screen down.
Lift the LCD screen from the screen plate.
Lift the hinged lip on the camera body where the ribbon cable enters the connector.
Remove the ribbon from the logic board by gently pulling it straight out.
Try not to kink or crease the cable.
Separate the logic board by carefully pulling the logic board away from the camera.
Be careful not to damage the battery compartment. The battery sensors are attached to the logic board, so be gentle.
The USB connector is going to want to hang up on the housing, but once you have that free, the battery leads will slide out relatively easily.
2等其他人完成本指南。
