跳转到主内容
加入维修社区 - 创建账户
Samsung S860 LCD Screen Replacement
你所需要的
  1. Samsung S860 LCD Screen Replacement, LCD Screen: 步骤 1 中的图像 1,2 Samsung S860 LCD Screen Replacement, LCD Screen: 步骤 1 中的图像 2,2
    • Remove all screws along the edges of the camera, using a #00 Phillips screwdriver.
  2. Samsung S860 LCD Screen Replacement: 步骤 2 中的图像 1,1
    • Slide open the battery compartment cover before removing the exterior covers of the camera.
  3. Samsung S860 LCD Screen Replacement: 步骤 3 中的图像 1,3 Samsung S860 LCD Screen Replacement: 步骤 3 中的图像 2,3 Samsung S860 LCD Screen Replacement: 步骤 3 中的图像 3,3
    • Carefully pull the back case (the side showing the LCD screen) away from the front half.
    • There are clips securing the top of the back case. Do not be afraid to use the proper amount of force to remove the back case.
    • Turn the camera around to the front (the lens side). Carefully remove the front case.
    • There are also clips on the lens' side as well, so do not be afraid to use force.
  4. Samsung S860 LCD Screen Replacement: 步骤 4 中的图像 1,2 Samsung S860 LCD Screen Replacement: 步骤 4 中的图像 2,2
    • Position the camera so the LCD screen is facing you.
    • Remove the LCD screen from the screen plate.
    • Replace the broken LCD screen with the functioning LCD screen.
结论
3等其他人完成本指南。
Kando Ogunrinola
于04/17/10注册
203 声望
创作了3篇指南
团队
Cal Poly, Team 33-72, Johann Spring 2010 Cal Poly, Team 33-72, Johann Spring 2010 的会员
CPSU-JOHANN-S10S33G72
4 名成员
创作了7篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 11
过去 30 天: 49
总计 9,415
