跳转到主内容
Samsung S85 Rubber Door Replacement
你所需要的
  1. Samsung S85 Rubber Door Replacement, Rubber Door: 步骤 1 中的图像 1,3 Samsung S85 Rubber Door Replacement, Rubber Door: 步骤 1 中的图像 2,3 Samsung S85 Rubber Door Replacement, Rubber Door: 步骤 1 中的图像 3,3
    • Remove 4 screws from bottom of camera
    • Remove 2 screws from side of camera
    • Place Screws on magnetic surface or location where they will not roll away
  2. Samsung S85 Rubber Door Replacement: 步骤 2 中的图像 1,1
    • Squeeze area noted by blue square and pull outside shell apart from remaining camera.
  3. Samsung S85 Rubber Door Replacement: 步骤 3 中的图像 1,2 Samsung S85 Rubber Door Replacement: 步骤 3 中的图像 2,2
    • Remove 6 screws identified by red circles
    • Remove 3 screws identified by orange circles
  4. Samsung S85 Rubber Door Replacement: 步骤 4 中的图像 1,2 Samsung S85 Rubber Door Replacement: 步骤 4 中的图像 2,2
    • Gently remove orange circuit ribbon identified by red square
    • Gently remove narrow orange circuit ribbon identified by blue square
  5. Samsung S85 Rubber Door Replacement: 步骤 5 中的图像 1,3 Samsung S85 Rubber Door Replacement: 步骤 5 中的图像 2,3 Samsung S85 Rubber Door Replacement: 步骤 5 中的图像 3,3
    • Be very cautious when using a soldering iron (they are on average 300 F)
    • Using a soldering iron, remove solder from wire identified by red circle
    • Using a soldering iron, remove solder from black and red wire identified by orange circle
    • Using a soldering iron, remove solder from wire identified by yellow circle
  6. Samsung S85 Rubber Door Replacement: 步骤 6 中的图像 1,3 Samsung S85 Rubber Door Replacement: 步骤 6 中的图像 2,3 Samsung S85 Rubber Door Replacement: 步骤 6 中的图像 3,3
    • Using soldering iron, melt away solder and warm up metal located at top of circuit board as shown in picture
    • Repeat step two to three times until board feels flexible to bend
    • Slowly bend circuit board upwards (towards power button) until at 90 degree angle with remaining part of camera.
  7. Samsung S85 Rubber Door Replacement: 步骤 7 中的图像 1,1
    在这个步骤中使用的工具:
    购买
    • Remove black rubber door located on side of camera closest to lens using tweezers.
    • Be careful not to bend or tear the rubber when pulling out with tweezers as it may become difficult to put back in
结论
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 6
总计 282
