跳转到主内容
Samsung S85 Battery Door Replacement
你所需要的
  1. Samsung S85 Battery Door Replacement, Battery Door: 步骤 1 中的图像 1,3 Samsung S85 Battery Door Replacement, Battery Door: 步骤 1 中的图像 2,3 Samsung S85 Battery Door Replacement, Battery Door: 步骤 1 中的图像 3,3
    在这个步骤中使用的工具:
    • Rotate camera such that battery door is facing upwards. Open battery as if you normally would when changing batteries
    • Bend paperclip such that metal is now a thin rod
    • Align rod portion of paperclip with pin located at bottom of battery door. Gently push on pin with rod such that rod replaces pin underneath battery door as shown in first picture
    • Be careful with spring located with pin as this may fly off when being pushed out by paperclip.
    • Using tweezers, gently pull pin out from opposite end of paperclip. When pin is fully removed, remove paper clip.
    • Battery door should now be fully removed from battery slot.
结论
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 4
总计 812
