简介
The LCD screen can be cracked or water damaged
你所需要的
Placing your thumb on the battery cover, push outwards, away from the camera in the direction the arrow is pointing. If done correctly when it's completely unhooked, the latch will open.
Locate and remove the six 4mm screws on the sides of the camera, using the Phillip Screwdriver #000 bit.
即将完成!
结论
另外一个人完成了本指南。
