跳转到主内容
Samsung S760 Front and Back Case Replacement Guide
你所需要的
  1. Samsung S760 Front and Back Case Replacement Guide, Battery: 步骤 1 中的图像 1,3 Samsung S760 Front and Back Case Replacement Guide, Battery: 步骤 1 中的图像 2,3 Samsung S760 Front and Back Case Replacement Guide, Battery: 步骤 1 中的图像 3,3
    • Placing your thumb on the battery cover, push outwards, away from the camera in the direction the arrow is pointing. If done correctly when it's completely unhooked, the latch will open.
  2. Samsung S760 Front and Back Case Replacement Guide: 步骤 2 中的图像 1,2 Samsung S760 Front and Back Case Replacement Guide: 步骤 2 中的图像 2,2
    • Tip the camera as to gently slide the batteries out of the camera.
  3. Samsung S760 Front and Back Case Replacement Guide, Front and Back Case: 步骤 3 中的图像 1,3 Samsung S760 Front and Back Case Replacement Guide, Front and Back Case: 步骤 3 中的图像 2,3 Samsung S760 Front and Back Case Replacement Guide, Front and Back Case: 步骤 3 中的图像 3,3
    • All screws in this camera are removed using the Phillip Screwdriver #000 bit. Also, all dimensions included refer to screw lengths.
    • Locate and remove the six 4mm screws on the sides of the camera.
  4. Samsung S760 Front and Back Case Replacement Guide: 步骤 4 中的图像 1,2 Samsung S760 Front and Back Case Replacement Guide: 步骤 4 中的图像 2,2
    • Use the plastic opening tool to pry open the back case, following alongside the edge of the case if need be.
  5. Samsung S760 Front and Back Case Replacement Guide: 步骤 5 中的图像 1,1
    • Once the back case is removed, use the plastic opening tool to gently pry off the front case.
结论
This will be used as a prerequisite to other guides. To reassemble your device, follow these instructions in reverse order.
4等其他人完成本指南。
团队
UMass Dartmouth, Team S8-G1, Catania Spring 2017 UMass Dartmouth, Team S8-G1, Catania Spring 2017 的会员
UMASSD-CATANIA-S17S8G1
3 名成员
创作了14篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 9
总计 678
