跳转到主内容
Samsung S760 Camera Lens Replacement Guide
你所需要的
  1. Samsung S760 Camera Lens Replacement Guide, Battery: 步骤 1 中的图像 1,3 Samsung S760 Camera Lens Replacement Guide, Battery: 步骤 1 中的图像 2,3 Samsung S760 Camera Lens Replacement Guide, Battery: 步骤 1 中的图像 3,3
    • Placing your thumb on the battery cover, push outwards, away from the camera in the direction the arrow is pointing. If done correctly when it's completely unhooked, the latch will open.
  2. Samsung S760 Camera Lens Replacement Guide: 步骤 2 中的图像 1,2 Samsung S760 Camera Lens Replacement Guide: 步骤 2 中的图像 2,2
    • Tip the camera as to gently slide the batteries out of the camera.
  3. Samsung S760 Camera Lens Replacement Guide, Front and Back Case: 步骤 3 中的图像 1,3 Samsung S760 Camera Lens Replacement Guide, Front and Back Case: 步骤 3 中的图像 2,3 Samsung S760 Camera Lens Replacement Guide, Front and Back Case: 步骤 3 中的图像 3,3
    • All screws in this camera are removed using the Phillip Screwdriver #000 bit. Also, all dimensions included refer to screw lengths.
    • Locate and remove the six 4mm screws on the sides of the camera.
  4. Samsung S760 Camera Lens Replacement Guide: 步骤 4 中的图像 1,2 Samsung S760 Camera Lens Replacement Guide: 步骤 4 中的图像 2,2
    • Use the plastic opening tool to pry open the back case, following alongside the edge of the case if need be.
  5. Samsung S760 Camera Lens Replacement Guide: 步骤 5 中的图像 1,1
    • Once the back case is removed, use the plastic opening tool to gently pry off the front case.
  6. Samsung S760 Camera Lens Replacement Guide, Camera Lens: 步骤 6 中的图像 1,1
    • Move the screen down, out of the way to remove the two 3mm screws beneath it.
  7. Samsung S760 Camera Lens Replacement Guide: 步骤 7 中的图像 1,2 Samsung S760 Camera Lens Replacement Guide: 步骤 7 中的图像 2,2
    • Remove the 6mm screw labeled in the picture.
    • Remove the three 3mm screws.
    • Then proceed to flip the screen to the other side to remove the other 6mm screw.
  8. Samsung S760 Camera Lens Replacement Guide: 步骤 8 中的图像 1,1
    • Proceed to carefully pull the ribbon cable out by using the little circular tabs sticking out on either side.
  9. Samsung S760 Camera Lens Replacement Guide: 步骤 9 中的图像 1,2 Samsung S760 Camera Lens Replacement Guide: 步骤 9 中的图像 2,2
    • Proceed to slowly pry off the mother board with the plastic opening tool by removing it at the micro USB attachment.
    • Then carefully manually pry off the golden colored section near the camera wheel until all of it is off.
  10. Samsung S760 Camera Lens Replacement Guide: 步骤 10 中的图像 1,2 Samsung S760 Camera Lens Replacement Guide: 步骤 10 中的图像 2,2
    • Finally, remove the final 3mm screw marked in the picture.
    • Lift the camera lens out of the lens compartment.
结论
4等其他人完成本指南。
David Sepulveda
于03/06/17注册
548 声望
创作了3篇指南
团队
UMass Dartmouth, Team S8-G1, Catania Spring 2017 UMass Dartmouth, Team S8-G1, Catania Spring 2017 的会员
UMASSD-CATANIA-S17S8G1
3 名成员
创作了12篇指南
2指南评论
Brilliantly explained. Makes it look so easy… even a fool such as I could follow the instructions.
frankasensale - 回复
the guide is actually beautiful im just upset that mine got corroded from battery leakage and rusted the capacitors next to the charging port and caused it to fall off :c
AboynamedJason - 回复
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 12
过去 30 天: 62
总计 2,032
