简介
The battery cover can break off fairly easily if you're not careful, as it is attached by only a single hinge. This guide will show you how to replace it.
你所需要的
Placing your thumb on the battery cover, push outwards, away from the camera in the direction the arrow is pointing. If done correctly when it's completely unhooked, the latch will open.
Using the pointed end of the Spudger, push the metal pin out of the hinge as far as it will go (this will typically be halfway).
即将完成!
结论
