跳转到主内容
Samsung Rogue Speaker/Antenna Replacement
你所需要的
  1. Samsung Rogue Speaker/Antenna Replacement, Battery: 步骤 1 中的图像 1,2 Samsung Rogue Speaker/Antenna Replacement, Battery: 步骤 1 中的图像 2,2
    • Before disassembling your Samsung Rogue, make sure it is powered off.
    • With your thumbs, push down on the back cover of your phone and slide it away from the camera.
  2. Samsung Rogue Speaker/Antenna Replacement: 步骤 2 中的图像 1,2 Samsung Rogue Speaker/Antenna Replacement: 步骤 2 中的图像 2,2
    • You can now remove the battery by prying it up with your finger.
  3. Samsung Rogue Speaker/Antenna Replacement, Motherboard: 步骤 3 中的图像 1,1
    • Use a plastic opening tool to carefully pry the back cover surrounding the camera up from the phone.
  4. Samsung Rogue Speaker/Antenna Replacement: 步骤 4 中的图像 1,1
    • Remove the five 3.4mm Philips screws securing the backing of the phone.
  5. Samsung Rogue Speaker/Antenna Replacement: 步骤 5 中的图像 1,3 Samsung Rogue Speaker/Antenna Replacement: 步骤 5 中的图像 2,3 Samsung Rogue Speaker/Antenna Replacement: 步骤 5 中的图像 3,3
    • Use a plastic opening tool to carefully pry off the back cover.
    • Make sure you are prying along the edge and not between the two halves of the phone that slide away from each other.
    • Be careful to not drop the volume changing piece, for it can easily slip out.
  6. Samsung Rogue Speaker/Antenna Replacement: 步骤 6 中的图像 1,1
    • Remove the two 3.45 mm Philips screws below the white sticker.
  7. Samsung Rogue Speaker/Antenna Replacement: 步骤 7 中的图像 1,2 Samsung Rogue Speaker/Antenna Replacement: 步骤 7 中的图像 2,2
    • Carefully lift the motherboard up from the bottom edge.
    • The film of wires is still attached to the motherboard, so do not completely remove the motherboard just yet or you may damage it.
  8. Samsung Rogue Speaker/Antenna Replacement: 步骤 8 中的图像 1,2 Samsung Rogue Speaker/Antenna Replacement: 步骤 8 中的图像 2,2
    • Use a plastic opening tool to disconnect the film from the motherboard.
  9. Samsung Rogue Speaker/Antenna Replacement, Speaker/Antenna: 步骤 9 中的图像 1,1
    • On the underside of the motherboard, remove the single 3.3mm Philips screw.
  10. Samsung Rogue Speaker/Antenna Replacement: 步骤 10 中的图像 1,3 Samsung Rogue Speaker/Antenna Replacement: 步骤 10 中的图像 2,3 Samsung Rogue Speaker/Antenna Replacement: 步骤 10 中的图像 3,3
    • The speaker and the antenna are both connected on the same black piece.
    • Use a plastic opening tool to pop off the edges of the speaker/antenna piece from the motherboard.
    • Turn over the motherboard and carefully lift the speaker/antenna piece straight up.
    • The camera is held in the middle of the speaker/antenna piece. Make sure to lift directly up when lifting the speaker/antenna piece, otherwise you can risk damaging the camera.
结论
团队
Cal Poly, Team 7-32, Maness Spring 2012 Cal Poly, Team 7-32, Maness Spring 2012 的会员
CPSU-MANESS-S12S7G32
4 名成员
创作了16篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 355
