跳转到主内容
Samsung Refrigerator Fuse Block Replacement
你所需要的
  1. Samsung Refrigerator Fuse Block Replacement, Unplug your refrigerator: 步骤 1 中的图像 1,1
    • Unplug your refrigerator before you begin your repair.
    • If you are testing or repairing the following items, you may also need to shut off and disconnect the water supply:
    • Condenser fan motor
    • Compressor motor and thermal overload device
    • Water supply valve assembly
  2. Samsung Refrigerator Fuse Block Replacement, Remove the board access panel: 步骤 2 中的图像 1,1
    • Remove the screws securing the board access panel to the back of the refrigerator.
  3. Samsung Refrigerator Fuse Block Replacement: 步骤 3 中的图像 1,2 Samsung Refrigerator Fuse Block Replacement: 步骤 3 中的图像 2,2
    • Remove the board access panel.
  4. Samsung Refrigerator Fuse Block Replacement, Remove the fuse block: 步骤 4 中的图像 1,3 Samsung Refrigerator Fuse Block Replacement, Remove the fuse block: 步骤 4 中的图像 2,3 Samsung Refrigerator Fuse Block Replacement, Remove the fuse block: 步骤 4 中的图像 3,3
    • Squeeze the wide sides of the red connector to unlatch it from the fuse block.
    • Pull to disconnect the connector.
    • Repeat the procedure to disconnect the blue connector.
    • During reassembly, make sure the connectors lock in place. If they don't, you may need to flip their orientation.
  5. Samsung Refrigerator Fuse Block Replacement: 步骤 5 中的图像 1,3 Samsung Refrigerator Fuse Block Replacement: 步骤 5 中的图像 2,3 Samsung Refrigerator Fuse Block Replacement: 步骤 5 中的图像 3,3
    • Use your fingers to pry and release the black plastic clip holding the left edge of the fuse block.
    • Lift out and remove the fuse block.
结论
Repair didn’t go as planned? Ask our Answers Community for help.
另外一个人完成了本指南。
nicO
于04/14/15注册
15,945 声望
创作了89篇指南
团队
Team Vulcan Team Vulcan 的会员
Staff
6 名成员
创作了212篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 18
过去 30 天: 102
总计 3,760
