简介
This guide shows how to replace the evaporator thermistor in your Samsung refrigerator.
Some Samsung refrigerators have two evaporators: one for the refrigerator compartment and one for the freezer. This guide is for the refrigerator evaporator thermistor.
This thermistor does not sense the refrigerator compartment temperature. Rather, this thermistor senses the evaporator coil temperature. If this thermistor fails, your refrigerator won't cool the refrigerator compartment properly.
This guide will work for most Samsung Refrigerators . This guide is based on a model RF28R7201SG Refrigerator. If you have a different model, you may encounter some minor disassembly differences, but the overall repair process will be the same
你所需要的
Use a flathead screwdriver to pry and remove the top screw cover on the evaporator cover.
Use a flathead screwdriver to pry off and remove any connector retaining clips.
Use your fingers to twist and unclip the thermistor from the evaporator coil.
Remove the evaporator thermistor.
Repair didn’t go as planned? Ask our Answers Community for help.
