跳转到主内容
Samsung Refrigerator Evaporator Fan (Refrigerator Compartment) Replacement
你所需要的
  1. Samsung Refrigerator Evaporator Fan (Refrigerator Compartment) Replacement, Unplug your refrigerator: 步骤 1 中的图像 1,1
    • Unplug your refrigerator before you begin your repair.
    • If you are testing or repairing the following items, you may also need to shut off and disconnect the water supply:
    • Condenser fan motor
    • Compressor motor and thermal overload device
    • Water supply valve assembly
  2. Samsung Refrigerator Evaporator Fan (Refrigerator Compartment) Replacement, Open the refrigerator doors: 步骤 2 中的图像 1,2 Samsung Refrigerator Evaporator Fan (Refrigerator Compartment) Replacement, Open the refrigerator doors: 步骤 2 中的图像 2,2
    • Open both French doors for the refrigerator compartment.
  3. Samsung Refrigerator Evaporator Fan (Refrigerator Compartment) Replacement, Remove the shelves: 步骤 3 中的图像 1,2 Samsung Refrigerator Evaporator Fan (Refrigerator Compartment) Replacement, Remove the shelves: 步骤 3 中的图像 2,2
    • Remove all the loose shelves and bins from the refrigerator compartment.
    • The bottom shelf is clipped in place. Follow the next step to remove it.
  4. Samsung Refrigerator Evaporator Fan (Refrigerator Compartment) Replacement: 步骤 4 中的图像 1,3 Samsung Refrigerator Evaporator Fan (Refrigerator Compartment) Replacement: 步骤 4 中的图像 2,3 Samsung Refrigerator Evaporator Fan (Refrigerator Compartment) Replacement: 步骤 4 中的图像 3,3
    • Two stiff plastic tabs (one on each side) secure the bottom shelf in place.
    • Press both plastic tabs firmly with your fingers and lift upward to unclip the bottom shelf.
    • If the shelf doesn't unclip, you can try using a flathead screwdriver to press each clip in.
    • Remove the bottom shelf.
  5. Samsung Refrigerator Evaporator Fan (Refrigerator Compartment) Replacement, Remove the refrigerator evaporator cover: 步骤 5 中的图像 1,3 Samsung Refrigerator Evaporator Fan (Refrigerator Compartment) Replacement, Remove the refrigerator evaporator cover: 步骤 5 中的图像 2,3 Samsung Refrigerator Evaporator Fan (Refrigerator Compartment) Replacement, Remove the refrigerator evaporator cover: 步骤 5 中的图像 3,3
    • Use a flathead screwdriver to pry and remove the top screw cover on the evaporator cover.
  6. Samsung Refrigerator Evaporator Fan (Refrigerator Compartment) Replacement: 步骤 6 中的图像 1,1
    • Remove the screws securing the evaporator cover.
  7. Samsung Refrigerator Evaporator Fan (Refrigerator Compartment) Replacement: 步骤 7 中的图像 1,3 Samsung Refrigerator Evaporator Fan (Refrigerator Compartment) Replacement: 步骤 7 中的图像 2,3 Samsung Refrigerator Evaporator Fan (Refrigerator Compartment) Replacement: 步骤 7 中的图像 3,3
    • Grasp the right edge of the evaporator cover with your hands and swing it outwards toward you.
    • Don't try to fully remove the cover in this step, as it's connected by several wires.
  8. Samsung Refrigerator Evaporator Fan (Refrigerator Compartment) Replacement: 步骤 8 中的图像 1,1
    • Squeeze and disconnect all the wire connectors connecting the evaporator cover to the refrigerator.
  9. Samsung Refrigerator Evaporator Fan (Refrigerator Compartment) Replacement: 步骤 9 中的图像 1,2 Samsung Refrigerator Evaporator Fan (Refrigerator Compartment) Replacement: 步骤 9 中的图像 2,2
    • Pull the evaporator cover towards you and remove it.
  10. Samsung Refrigerator Evaporator Fan (Refrigerator Compartment) Replacement, Remove the evaporator fan: 步骤 10 中的图像 1,1
    • Remove the screws securing the fan bracket to the evaporator cover.
  11. Samsung Refrigerator Evaporator Fan (Refrigerator Compartment) Replacement: 步骤 11 中的图像 1,2 Samsung Refrigerator Evaporator Fan (Refrigerator Compartment) Replacement: 步骤 11 中的图像 2,2
    • Remove the fan cable from the cover clips.
    • If you have trouble getting the cable out of the clips, squeeze the clips with pliers to create a wider gap.
  12. Samsung Refrigerator Evaporator Fan (Refrigerator Compartment) Replacement: 步骤 12 中的图像 1,2 Samsung Refrigerator Evaporator Fan (Refrigerator Compartment) Replacement: 步骤 12 中的图像 2,2
    • Lift the loose edge of the fan bracket up.
  13. Samsung Refrigerator Evaporator Fan (Refrigerator Compartment) Replacement: 步骤 13 中的图像 1,2 Samsung Refrigerator Evaporator Fan (Refrigerator Compartment) Replacement: 步骤 13 中的图像 2,2
    • The fan is pressure-fit in place with some foam insulation.
    • Use your fingers to press the fan out of its recess.
  14. Samsung Refrigerator Evaporator Fan (Refrigerator Compartment) Replacement: 步骤 14 中的图像 1,1
    • Remove the fan.
    • During reassembly, be sure to install the fan in the right orientation: the side with the center label should face down, towards the evaporator cover.
结论
Repair didn’t go as planned? Ask our Answers Community for help.
2等其他人完成本指南。
nicO
于04/14/15注册
15,945 声望
创作了89篇指南
团队
Team Vulcan Team Vulcan 的会员
Staff
6 名成员
创作了212篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 27
过去 30 天: 151
总计 4,388
