跳转到主内容
Samsung Refrigerator Door Sensors Replacement
你所需要的
  1. Samsung Refrigerator Door Sensors Replacement, Unplug your refrigerator: 步骤 1 中的图像 1,1
    • Unplug your refrigerator before you begin your repair.
  2. Samsung Refrigerator Door Sensors Replacement, Remove the hinge cover: 步骤 2 中的图像 1,1
    • Remove the screws securing the hinge cover (aka top table) on the top of the refrigerator.
  3. Samsung Refrigerator Door Sensors Replacement: 步骤 3 中的图像 1,1
    • Lift the edges of the hinge cover to loosen it from the refrigerator.
    • Don't try to fully remove the cover, as it's still attached to the refrigerator by a few cables.
    • Flip the hinge cover over to access the cables underneath.
  4. Samsung Refrigerator Door Sensors Replacement: 步骤 4 中的图像 1,2 Samsung Refrigerator Door Sensors Replacement: 步骤 4 中的图像 2,2
    • Use your fingers to release the wire connectors under the hinge cover.
    • Disconnect the wiring so you can remove the hinge cover.
  5. Samsung Refrigerator Door Sensors Replacement: 步骤 5 中的图像 1,1
    • Remove the hinge cover.
  6. Samsung Refrigerator Door Sensors Replacement, Sensor information: 步骤 6 中的图像 1,2 Samsung Refrigerator Door Sensors Replacement, Sensor information: 步骤 6 中的图像 2,2
    • The door sensors are located in the hinge cover. In this example, the hinge cover has two door sensors:
    • The left door sensor
    • The left door sensor connector
    • The right door sensor
    • The right door sensor connector
    • Depending on your situation, you may need to replace either or both sensors.
  7. Samsung Refrigerator Door Sensors Replacement, Remove the sensor: 步骤 7 中的图像 1,2 Samsung Refrigerator Door Sensors Replacement, Remove the sensor: 步骤 7 中的图像 2,2
    • Use your fingers to squeeze and disconnect the sensor cable connector.
  8. Samsung Refrigerator Door Sensors Replacement: 步骤 8 中的图像 1,2 Samsung Refrigerator Door Sensors Replacement: 步骤 8 中的图像 2,2
    • Use a spudger or a flathead screwdriver to pry the sensor out of its retaining clips.
  9. Samsung Refrigerator Door Sensors Replacement: 步骤 9 中的图像 1,1
    • Remove the door sensor.
结论
Repair didn’t go as planned? Ask our Answers Community for help.
nicO
于04/14/15注册
15,927 声望
创作了88篇指南
团队
Global Fixers Global Fixers 的会员
Community
33 名成员
创作了572篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 11
过去 7 天: 109
过去 30 天: 419
总计 2,738
