跳转到主内容
Samsung Refrigerator Control Panel Replacement
你所需要的
  1. Samsung Refrigerator Control Panel Replacement, Unplug your refrigerator: 步骤 1 中的图像 1,1
    • Unplug your refrigerator before you begin your repair.
    • If you are testing or repairing the following items, you may also need to shut off and disconnect the water supply:
    • Condenser fan motor
    • Compressor motor and thermal overload device
    • Water supply valve assembly
  2. Samsung Refrigerator Control Panel Replacement, Open the refrigerator doors: 步骤 2 中的图像 1,2 Samsung Refrigerator Control Panel Replacement, Open the refrigerator doors: 步骤 2 中的图像 2,2
    • Open both French doors for the refrigerator compartment.
  3. Samsung Refrigerator Control Panel Replacement, Loosen the control panel: 步骤 3 中的图像 1,3 Samsung Refrigerator Control Panel Replacement, Loosen the control panel: 步骤 3 中的图像 2,3 Samsung Refrigerator Control Panel Replacement, Loosen the control panel: 步骤 3 中的图像 3,3
    • The control panel has plastic clips around its perimeter that secure it to the refrigerator wall.
    • Insert a spudger into the seam along the right edge of the control panel.
    • You can also use a flathead screwdriver, but be careful not to let the screwdriver slip, or you'll scratch your refrigerator surface.
    • Press the spudger in firmly and pry to loosen the panel.
    • Use your spudger to slide and pry around the control panel to loosen it from the refrigerator wall.
  4. Samsung Refrigerator Control Panel Replacement: 步骤 4 中的图像 1,1
    • Flip the control panel over to reveal the cable connector.
  5. Samsung Refrigerator Control Panel Replacement: 步骤 5 中的图像 1,2 Samsung Refrigerator Control Panel Replacement: 步骤 5 中的图像 2,2
    • Use your fingers to slide the cable connector out of its socket.
  6. Samsung Refrigerator Control Panel Replacement, Remove the control panel: 步骤 6 中的图像 1,1
    • Remove the control panel.
结论
Repair didn’t go as planned? Ask our Answers Community for help.
nicO
于04/14/15注册
15,945 声望
创作了89篇指南
团队
Team Vulcan Team Vulcan 的会员
Staff
6 名成员
创作了212篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 36
过去 30 天: 118
总计 3,532
