跳转到主内容
Samsung Rant Keypad Replacement
你所需要的
  1. Samsung Rant Keypad Replacement, Back Cover: 步骤 1 中的图像 1,1
    • Turn the phone over in the palm of your hand, with the screen facing down.
    • While grasping the bottom part of the phone with one hand, use your thumb to push the release button at the end of the phone.
    • This will release the back plate latch; then lift the back plate up and out toward the other end of the phone.
    • You should now be able to lift the plate completely off of the phone.
  2. Samsung Rant Keypad Replacement, Battery: 步骤 2 中的图像 1,1
    • Carefully remove the battery from the phone.
  3. Samsung Rant Keypad Replacement, Rear Case: 步骤 3 中的图像 1,1
    • Use a Phillips #00 screwdriver to loosen and remove all 3 screws.
  4. Samsung Rant Keypad Replacement: 步骤 4 中的图像 1,1
    • Gently separate the rear case from the front case.
  5. Samsung Rant Keypad Replacement, Keypad: 步骤 5 中的图像 1,2 Samsung Rant Keypad Replacement, Keypad: 步骤 5 中的图像 2,2
    在这个步骤中使用的工具:
    • Using a pair of tweezers, grip the keypad gently.
    • Lift the keypad out of the phone and replace it (if necessary).
结论
Denise Cooper
于10/18/11注册
31 声望
创作了3篇指南
团队
James Madison, Team 1-6, Allen Fall 2011 James Madison, Team 1-6, Allen Fall 2011 的会员
JMU-ALLEN-F11S1G6
4 名成员
创作了12篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 6
过去 30 天: 17
总计 1,632
