跳转到主内容
Samsung Radiant360 R3 Wireless Setup Button and USB Module Replacement
你所需要的
  1. Samsung Radiant360 R3 Wireless Setup Button and USB Module Replacement, Wireless Setup Button and USB Module: 步骤 1 中的图像 1,3 Samsung Radiant360 R3 Wireless Setup Button and USB Module Replacement, Wireless Setup Button and USB Module: 步骤 1 中的图像 2,3 Samsung Radiant360 R3 Wireless Setup Button and USB Module Replacement, Wireless Setup Button and USB Module: 步骤 1 中的图像 3,3
    • Flip the device so that the bottom of the device is facing you. Remove these feet with a pair of tweezers.
    • Remove the four 10mm long screws with the Phillips #1 screwdriver.
  2. Samsung Radiant360 R3 Wireless Setup Button and USB Module Replacement: 步骤 2 中的图像 1,1
    • Remove the bottom shell from the speaker.
  3. Samsung Radiant360 R3 Wireless Setup Button and USB Module Replacement: 步骤 3 中的图像 1,2 Samsung Radiant360 R3 Wireless Setup Button and USB Module Replacement: 步骤 3 中的图像 2,2
    • Remove the connector from the board by pressing down on the center tab while nudging the connector away with a spudger.
    • Be careful not to pull directly on the wires or apply too much pressure, or you risk breaking the connector.
  4. Samsung Radiant360 R3 Wireless Setup Button and USB Module Replacement: 步骤 4 中的图像 1,1
    • Remove the two 10mm long screws from the board utilizing the Phillips #1 screwdriver.
  5. Samsung Radiant360 R3 Wireless Setup Button and USB Module Replacement: 步骤 5 中的图像 1,1
    • Use a spudger to press the plastic tab away from the board until the board pops up.
    • Remove the board with the USB module from the device.
结论
另外一个人完成了本指南。
Fadi Alzammar
于04/22/18注册
782 声望
创作了5篇指南
团队
Cal Poly, Team S25-G18, Maness Spring 2018 Cal Poly, Team S25-G18, Maness Spring 2018 的会员
CPSU-MANESS-S18S25G18
4 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 7
总计 259
