跳转到主内容
Samsung Radiant360 R3 Wireless Module Replacement
你所需要的
  1. Samsung Radiant360 R3 Wireless Module Replacement, Wireless Setup Button and USB Module: 步骤 1 中的图像 1,3 Samsung Radiant360 R3 Wireless Module Replacement, Wireless Setup Button and USB Module: 步骤 1 中的图像 2,3 Samsung Radiant360 R3 Wireless Module Replacement, Wireless Setup Button and USB Module: 步骤 1 中的图像 3,3
    • Flip the device so that the bottom of the device is facing you. Remove these feet with a pair of tweezers.
    • Remove the four 10mm long screws with the Phillips #1 screwdriver.
  2. Samsung Radiant360 R3 Wireless Module Replacement: 步骤 2 中的图像 1,1
    • Remove the bottom shell from the speaker.
  3. Samsung Radiant360 R3 Wireless Module Replacement: 步骤 3 中的图像 1,2 Samsung Radiant360 R3 Wireless Module Replacement: 步骤 3 中的图像 2,2
    • Remove the connector from the board by pressing down on the center tab while nudging the connector away with a spudger.
    • Be careful not to pull directly on the wires or apply too much pressure, or you risk breaking the connector.
  4. Samsung Radiant360 R3 Wireless Module Replacement: 步骤 4 中的图像 1,1
    • Remove the two 10mm long screws from the board utilizing the Phillips #1 screwdriver.
  5. Samsung Radiant360 R3 Wireless Module Replacement: 步骤 5 中的图像 1,1
    • Use a spudger to press the plastic tab away from the board until the board pops up.
    • Remove the board with the USB module from the device.
  6. Samsung Radiant360 R3 Wireless Module Replacement, Wireless Module: 步骤 6 中的图像 1,2 Samsung Radiant360 R3 Wireless Module Replacement, Wireless Module: 步骤 6 中的图像 2,2
    • Remove the two 12mm long screws with the Phillips #1 screwdriver.
    • Unplug white plug connected to the green circuit board.
  7. Samsung Radiant360 R3 Wireless Module Replacement: 步骤 7 中的图像 1,2 Samsung Radiant360 R3 Wireless Module Replacement: 步骤 7 中的图像 2,2
    • Remove the four 12mm long screws with the Phillips #1 screwdriver.
    • Remove the cover, and slide the cord through the hole.
  8. Samsung Radiant360 R3 Wireless Module Replacement: 步骤 8 中的图像 1,3 Samsung Radiant360 R3 Wireless Module Replacement: 步骤 8 中的图像 2,3 Samsung Radiant360 R3 Wireless Module Replacement: 步骤 8 中的图像 3,3
    • Remove rubber covers covering the screws with pair of tweezers.
    • Remove the six 12mm screws that are under the rubber covers with the Phillips #1 screwdriver.
  9. Samsung Radiant360 R3 Wireless Module Replacement: 步骤 9 中的图像 1,1
    • Remove the unscrewed cover as much as possible.
    • It is very difficult to get plugs at the end of the cord through the cover without breaking, so just slide to the edge.
  10. Samsung Radiant360 R3 Wireless Module Replacement: 步骤 10 中的图像 1,3 Samsung Radiant360 R3 Wireless Module Replacement: 步骤 10 中的图像 2,3 Samsung Radiant360 R3 Wireless Module Replacement: 步骤 10 中的图像 3,3
    • Push the body out through the outer shell of device.
    • Carefully push the ring attached to the cable through the shell.
  11. Samsung Radiant360 R3 Wireless Module Replacement: 步骤 11 中的图像 1,3 Samsung Radiant360 R3 Wireless Module Replacement: 步骤 11 中的图像 2,3 Samsung Radiant360 R3 Wireless Module Replacement: 步骤 11 中的图像 3,3
    • Remove the eight 12mm long screws around the body with the Phillips #1 screwdriver.
  12. Samsung Radiant360 R3 Wireless Module Replacement: 步骤 12 中的图像 1,2 Samsung Radiant360 R3 Wireless Module Replacement: 步骤 12 中的图像 2,2
    • Pry the two halves of the body open using a metal spudger.
  13. Samsung Radiant360 R3 Wireless Module Replacement: 步骤 13 中的图像 1,3 Samsung Radiant360 R3 Wireless Module Replacement: 步骤 13 中的图像 2,3 Samsung Radiant360 R3 Wireless Module Replacement: 步骤 13 中的图像 3,3
    • Remove the plugs located topmost right and closest to the bottom in picture.
  14. Samsung Radiant360 R3 Wireless Module Replacement: 步骤 14 中的图像 1,1
    • Remove the four 12mm long screws with the Phillips #1 screwdriver .
  15. Samsung Radiant360 R3 Wireless Module Replacement: 步骤 15 中的图像 1,1
    • Unscrew the four 8mm screws on the side of the motherboard with the Phillips #1 screwdriver .
    • Remove the Wireless Module from the device.
结论
Fadi Alzammar
于04/22/18注册
782 声望
创作了5篇指南
团队
Cal Poly, Team S25-G18, Maness Spring 2018 Cal Poly, Team S25-G18, Maness Spring 2018 的会员
CPSU-MANESS-S18S25G18
4 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 3
总计 272
