简介
This guide will take you through the process of removing the bottom of the speaker, separating the shell of the enclosure, and accessing the motherboard for removal.
你所需要的
Flip the device so that the bottom of the device is facing you. Remove these feet with a pair of tweezers.
Remove the four 10mm long screws with the Phillips #1 screwdriver.
Remove the two 12mm long screws with the Phillips #1 screwdriver.
Unplug white plug connected to the green circuit board.
另外一个人完成了本指南。
