简介
The woofer speaker is responsible for all the deep bass sounds in your speaker, and if you hear any weird rattling or pinging noises there is a good chance your woofer speaker will need to be replaced. This guide will demonstrate how to replace the woofer speaker in the Samsung Radiant 360 R1.
你所需要的
Use the plastic opening tool to lift and remove the rubber grommet plugs.
Remove the eight (9.5mm x 1.66mm) PH1 Phillips screws on the right side of the speaker body.
Remove the one (9.5mm x 1.66mm) PH1 Phillips head screws on the left side of the speaker body.
3等其他人完成本指南。
