跳转到主内容
Samsung RF28R7201SG Refrigerator Icemaker Assembly Replacement
你所需要的
  1. Samsung RF28R7201SG Refrigerator Icemaker Assembly Replacement, Unplug your refrigerator: 步骤 1 中的图像 1,1
    • Unplug your refrigerator before you begin your repair.
  2. Samsung RF28R7201SG Refrigerator Icemaker Assembly Replacement, Open the refrigerator doors: 步骤 2 中的图像 1,2 Samsung RF28R7201SG Refrigerator Icemaker Assembly Replacement, Open the refrigerator doors: 步骤 2 中的图像 2,2
    • Open both French doors for the refrigerator compartment.
  3. Samsung RF28R7201SG Refrigerator Icemaker Assembly Replacement, Remove the ice tray: 步骤 3 中的图像 1,3 Samsung RF28R7201SG Refrigerator Icemaker Assembly Replacement, Remove the ice tray: 步骤 3 中的图像 2,3 Samsung RF28R7201SG Refrigerator Icemaker Assembly Replacement, Remove the ice tray: 步骤 3 中的图像 3,3
    • Pull the ice tray straight out of its housing and remove it.
  4. Samsung RF28R7201SG Refrigerator Icemaker Assembly Replacement, Unfasten the cable cover panel: 步骤 4 中的图像 1,2 Samsung RF28R7201SG Refrigerator Icemaker Assembly Replacement, Unfasten the cable cover panel: 步骤 4 中的图像 2,2
    • Use a Phillips screwdriver to remove the 16.5 mm‑long screw securing the cable cover panel.
  5. Samsung RF28R7201SG Refrigerator Icemaker Assembly Replacement, Remove the cable cover panel: 步骤 5 中的图像 1,3 Samsung RF28R7201SG Refrigerator Icemaker Assembly Replacement, Remove the cable cover panel: 步骤 5 中的图像 2,3 Samsung RF28R7201SG Refrigerator Icemaker Assembly Replacement, Remove the cable cover panel: 步骤 5 中的图像 3,3
    • Use your fingers to slide the cable cover panel towards the front of the refrigerator to unlatch it.
    • Remove the cable cover panel.
    • During reassembly, make sure this panel clips fully in place, or the ice tray won't slide in properly.
  6. Samsung RF28R7201SG Refrigerator Icemaker Assembly Replacement, Disconnect the icemaker harness: 步骤 6 中的图像 1,2 Samsung RF28R7201SG Refrigerator Icemaker Assembly Replacement, Disconnect the icemaker harness: 步骤 6 中的图像 2,2
    • Disconnect the left-most yellow connector:
    • Squeeze the locking tab with the red mark with your fingers
    • Rock the connector gently side to side to disconnect it
    • Use your fingers or a screwdriver to guide the wire harness out of the wall clips.
  7. Samsung RF28R7201SG Refrigerator Icemaker Assembly Replacement, Unfasten the air tunnel: 步骤 7 中的图像 1,1
    • Use a Phillips screwdriver to remove the 16.5 mm-long screw securing the air tunnel flap.
  8. Samsung RF28R7201SG Refrigerator Icemaker Assembly Replacement, Remove the icemaker assembly: 步骤 8 中的图像 1,3 Samsung RF28R7201SG Refrigerator Icemaker Assembly Replacement, Remove the icemaker assembly: 步骤 8 中的图像 2,3 Samsung RF28R7201SG Refrigerator Icemaker Assembly Replacement, Remove the icemaker assembly: 步骤 8 中的图像 3,3
    • A plastic clip holds the air tunnel flap in place.
    • Use a flathead screwdriver to pry and loosen the air tunnel flap from the plastic clip.
  9. Samsung RF28R7201SG Refrigerator Icemaker Assembly Replacement: 步骤 9 中的图像 1,2 Samsung RF28R7201SG Refrigerator Icemaker Assembly Replacement: 步骤 9 中的图像 2,2
    • Use your fingers to pull the air tunnel flap down enough to access the internals.
  10. Samsung RF28R7201SG Refrigerator Icemaker Assembly Replacement: 步骤 10 中的图像 1,2 Samsung RF28R7201SG Refrigerator Icemaker Assembly Replacement: 步骤 10 中的图像 2,2
    • Use a flathead screwdriver to gently pry the refrigerant loop down by 1–1.5 cm.
    • During reassembly, use your fingers to push the refrigerant loop back up.
  11. Samsung RF28R7201SG Refrigerator Icemaker Assembly Replacement: 步骤 11 中的图像 1,3 Samsung RF28R7201SG Refrigerator Icemaker Assembly Replacement: 步骤 11 中的图像 2,3 Samsung RF28R7201SG Refrigerator Icemaker Assembly Replacement: 步骤 11 中的图像 3,3
    • A plastic clip holds the icemaker in place.
    • Use your fingers to press and release the plastic clip.
    • This clip is stiff and may require substantial force.
  12. Samsung RF28R7201SG Refrigerator Icemaker Assembly Replacement: 步骤 12 中的图像 1,2 Samsung RF28R7201SG Refrigerator Icemaker Assembly Replacement: 步骤 12 中的图像 2,2
    • Pull the front edge of the icemaker assembly down slightly to loosen it.
    • Be careful not to bend the refrigerant loop too much as you pull the front edge, or you'll damage the loop.
    • Carefully slide the icemaker assembly out of its housing.
  13. Samsung RF28R7201SG Refrigerator Icemaker Assembly Replacement: 步骤 13 中的图像 1,2 Samsung RF28R7201SG Refrigerator Icemaker Assembly Replacement: 步骤 13 中的图像 2,2
结论
Repair didn’t go as planned? Ask our Answers community for help.
nicO
于04/14/15注册
15,945 声望
创作了89篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 23
过去 30 天: 158
总计 2,419
