跳转到主内容
Samsung RF28R7201SG Refrigerator Control Board Replacement
你所需要的
  1. Samsung RF28R7201SG Refrigerator Control Board Replacement, Unplug your refrigerator: 步骤 1 中的图像 1,1
    • Unplug your refrigerator before you begin your repair.
  2. Samsung RF28R7201SG Refrigerator Control Board Replacement, Remove the board access panel: 步骤 2 中的图像 1,1
    • Use a Phillips screwdriver to remove the five screws securing the board access panel to the back of the refrigerator:
    • Four 14.8 mm-long screws
    • One 12.3 mm-long screw
  3. Samsung RF28R7201SG Refrigerator Control Board Replacement: 步骤 3 中的图像 1,2 Samsung RF28R7201SG Refrigerator Control Board Replacement: 步骤 3 中的图像 2,2
    • Remove the board access panel.
  4. Samsung RF28R7201SG Refrigerator Control Board Replacement, Reassembly information: 步骤 4 中的图像 1,2 Samsung RF28R7201SG Refrigerator Control Board Replacement, Reassembly information: 步骤 4 中的图像 2,2
    • The control board has nine wire connectors:
    • Three connectors along the top edge
    • One connector along the right edge
    • One connector along the bottom edge
    • Four connectors along the left edge
    • During reassembly, use the second image to make sure you've reconnected all nine connectors.
  5. Samsung RF28R7201SG Refrigerator Control Board Replacement, Remove the control board: 步骤 5 中的图像 1,2 Samsung RF28R7201SG Refrigerator Control Board Replacement, Remove the control board: 步骤 5 中的图像 2,2
    • Pull and disconnect each of the nine connectors from the control board.
    • Some connectors may have a locking tab. Squeeze the wide sides of the connector to unlock it, then pull to disconnect it.
    • Move the wires away from the control board so it can slide out of its recess.
  6. Samsung RF28R7201SG Refrigerator Control Board Replacement: 步骤 6 中的图像 1,3 Samsung RF28R7201SG Refrigerator Control Board Replacement: 步骤 6 中的图像 2,3 Samsung RF28R7201SG Refrigerator Control Board Replacement: 步骤 6 中的图像 3,3
    • Use your fingers to push up the plastic lip securing the top edge of the control board to the refrigerator.
    • Swing the control board out and remove it.
结论
Repair didn’t go as planned? Ask our Answers community for help.
nicO
于04/14/15注册
15,945 声望
创作了89篇指南
2指南评论
Hola, tengo un problema con mi refrigerador samsung RF28R7201SR/AA
Ada Medina - 回复
No enciende el abanico , de la parte de abajo ,ya lo cambie por uno nuevo y solo enciende 5 minutos y se apaga
Ada Medina - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 31
总计 415
