跳转到主内容
Samsung RF265BEAESR Water Filter Replacement
已存档的指南
本指南只作为历史记录保留。请使用指南的最新版本来进行维修。
你所需要的
  1. Samsung RF265BEAESR Water Filter Replacement, Water Filter: 步骤 1 中的图像 1,1
    • Open the refrigerator door to expose the water filter compartment in the center of the refrigerator (right above the bottom drawer).
  2. Samsung RF265BEAESR Water Filter Replacement: 步骤 2 中的图像 1,2 Samsung RF265BEAESR Water Filter Replacement: 步骤 2 中的图像 2,2
    • Rotate the knob of the filter counter-clockwise until the arrow lines up with the unlocked symbol.
  3. Samsung RF265BEAESR Water Filter Replacement: 步骤 3 中的图像 1,2 Samsung RF265BEAESR Water Filter Replacement: 步骤 3 中的图像 2,2
    • Once the filter is unlocked and can be moved freely, gently pull the filter towards you to remove it.
  4. Samsung RF265BEAESR Water Filter Replacement: 步骤 4 中的图像 1,1
    • Turn off the water supply to the refrigerator.
    • Drain all of the remaining water from the refrigerator using a large bowl or container. (Drain a minimum of 4 gallons)
  5. Samsung RF265BEAESR Water Filter Replacement: 步骤 5 中的图像 1,2 Samsung RF265BEAESR Water Filter Replacement: 步骤 5 中的图像 2,2
    • Insert the new filter and rotate it clockwise until it locks in place.
  6. Samsung RF265BEAESR Water Filter Replacement: 步骤 6 中的图像 1,1
    • Go to the "App Drawer" on the refrigerator screen.
    • Locate and select the "Fridge Manager" icon.
  7. Samsung RF265BEAESR Water Filter Replacement: 步骤 7 中的图像 1,1
    • Select "Fridge Settings" located at the bottom right corner of the screen.
  8. Samsung RF265BEAESR Water Filter Replacement: 步骤 8 中的图像 1,1
    • Select "Water Filter Replacement".
  9. Samsung RF265BEAESR Water Filter Replacement: 步骤 9 中的图像 1,1
    • Select "Reset" to reset the water filter.
    • Turn the water supply to the refrigerator back on.
    • Continue normal use of the water dispenser.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 3
总计 1,096
